Question about Insignia Car Audio & Video
I need to know how to wire duel voice coil 12
I need to know how to wire duel voice coil 12'' Insignia 1800 wts
One way if you want to run it off 1 channel is to wire one voice coil to the other making sure +goes to +, and -goes to -,then wire your amp to one of the coils, but i found just running each coil to a seperate channel on the same amp was the best way,
Posted on May 31, 2010
I have 2 duel 12' 2ohm sub's and a blackmore bac m-50 2000 watt 4ohm amp and was wondering how to wire. Thanks!
boz word of caution is to be heeded. with 2x2 ohms per speaker, you can only use one, with the voice coils ran in series to increase the resistance to 4 ohm . take a single driver, and use the series wiring on with both of the 2 ohm voice coils.
wire positive from the amp into positive of one voice coil, then the negative of that voice coil to the positive of the second voice coil 9bridging with 6 gauge or so, as was also mentioned by a previous user), then lead the negative of the second voice coil back to the amp's negative terminal.
Jun 01, 2015 | Car Audio & Video
Don't know how to wire a kicker solo-baric L7 2 ohm dual voice coil 12 inch sub
Wire in series for 4R. +ve of coil to amp +ve. -ve of that coil to +ve of second coil and the -ve of the second coil goes to -ve of amp.
Aug 10, 2017 | Car Audio & Video
Whats the best way to hook up a 12 inch dual voice coil insignia subwoofer spkr to a 4 channel 650 rev boss amp
Well without seeing a spec sheet on the amp and not knowing your voice coil impedance I will assume the following. If the speaker is dual 4 ohm voice coil the in parallel it would present a 2 ohm impedance to the amp. If this amp is stable down to 2 ohms bridged then that would be the hookup of choice. If it is not stable to two ohms with one speaker it will be tough to get full performance out of your amp. You would have to series the voice coils which would then present an 8 ohm impedance to the amp. Just look at your amp's manual before making the decision. My suggestion would be to get another one of those subwoofers parallel the voice coils on each then wire the two subwoofers in series. This would give you a 4 ohm load which your amp is almost certain to be able to drive.
Jan 28, 2010 | Boss REV-650 Car Audio Amplifier
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
How do i hook it up
On the Sub you have 4 connectors, 2 for each voice coil... Run a jumper wire from One side of the sub to the other. Positive to negative so that now you have one set of connectors free. Doing this will make the sub able to handle more cause you're using both voice coils. Thats how i've always hooked mine up when i have duel voice coil and they always last a long time. If you're gonna bridge the amp, make sure its turned down for about 5 or 6 hours to let the sub break in.
Mar 10, 2009 | Pioneer TS-W307D4 Car Subwoofer
Wiring a sub with duel voice coil
In short yes. And is very common even has its own term called bridged. Taking two channels and making them one. I would hope that you are running a cap. that's going to put out a lot of power and stress on your battery
Feb 10, 2009 | Lanzar (MAXP154D) 15'' 2000 Watt Dual...
12 inch insignia subwoofers model # ns-sub12
how to wire 12 inch insignia sub woofers
Apr 01, 2008 | Car Audio & Video
Subs
2x12 in sub each duel voice coil can iether wire to 1 or 4 ohms. im guessing you have everything wired up in series (1 ohm) and aer probably burning out the amp.
http://www.crutchfield.com/learningcenter/car/subwoofers_wiring.html?imageID=2DVC%5F4%2Dohm%5Fmono
Feb 25, 2008 | Car Audio & Video
Car Audio & Video Logo
Top Insignia Car Audio & Video Experts
xxxxxx xxx
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
