Home | Philips | 46PP9302 46 in. Rear Projection Television | Colors don't line up
Philips 46PP9302 46 in. Rear Projection Television
Problem for Philips 46PP9302 46 in. Rear Projection Television
By flameworx on Apr 08, 2008
I have a 52 inch magnavox projection tv the colors don't seem to line up at the top and the bottom. how do i fix it?
Best Solution
posted on Jul 05, 2009
Very Helpful)
techman
Rank: Guru  Philips Expert
Rating: 86%, 7605 votes
it sounds like you have a common convergence problem. to make this an easy repair go to tvrepairkits.com and order the complete convergence kit for your TV set it comes with the original replacement 's not those cheap aftermarket IC's or those popular factory reject IC's most people sell online or you buy online or in a local repair shop, also comes with resistors. pico fuses the thermal paste you need for the backs of the new IC's, full color pictorial instructions, and free live on-line tech assistance incase you run into a problem with the repair. Good Luck!!
Larry D
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Feb 10, 2009
Very Helpful)
tderf
Rank: Apprentice
Rating: 100%, 1 votes
my screen broke where can i find a new one
Was this helpful?
Yes
No
Solution #3
posted on Feb 13, 2009
Very Helpful)
Ecollier2012
Rating: 93%, 521 votes
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #4
posted on Apr 08, 2008
Not Rated)
joemari
Rank: Guide
Rating: 0%, 0 votes
hi,
try convergence alignment first. if still not working, you may have problem with the convergence ic. try and replace first.
good luck!
jorge
Was this helpful?
Yes
No
Popular Solutions for Philips 46PP9302 46 in. Rear
Questions and Unsolved Problems for Philips 46PP9302 46 in. Rear
Do you recommend Philips 46PP9302 46 in. Rear Projection Television?
Answer
Answer
the green light on the front of my tv its on and off but dont turn on the tv and the light still... (More)
Answer
the green light on the front of my tv bilcks once then shuts off and the back of the tv, clicks on... (More)
Answer
Sorry for the confusion, it is the input jacks that i plug playstation 2 and wii into. When I plug... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Philips 46PP9302 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1459
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
