Question about LG 24" XL Tall Tub Built-In Dishwasher - White
LG model LDS4821ST.... Top and Upper spray arms arn't rotating.
The unit is 15 months old. The bottom spray arm is working fine. I am suspect of the "Vario Spray System" which alternates, the pumps full power, between the upper and lower sprayers......
If anyone has any other ideas, or experience with this LG model, I would appreciate your input.
Thanks, Jeff in Pendleton, NY
I have an LG LDF8922ST model with the same exact problem (16 months old as well). I think you are right about the vario spray system. Seems like the repair guys that come out are clueless and get very little assistance from LG customer assistance. I will never buy another LG product again.
Posted on Dec 07, 2010
I have an LG model LDS4821 dishwasher that quit washing clean. Top rack is the dirtiest. Water is hot and bottom drain is clean.
The most likely cause is a blocked or clogged wash arm. Many times when the wash stops the debris blocking the spray will back away. The holes in the arm are aimed to cause the arm to rotate. The clogged hole is usually an outer diameter hole which provides the force for the arm to rotate.
Some upper end washers have a blocked arm sense to alert when arm is blocked.
Careful not to deform the geometry of the hole when removing the debris. Tweezers work the best.
26281729-v4uvew3xjjdpgmn3ctj2lcyg-4-2.jpg Hope this helps?
Sep 13, 2016 | LG Dishwashers
Upper spray arm
Hello Alan - Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Jun 24, 2013 | Frigidaire 24 in. FDB126RB Built-in...
The unit is 6 years old. Dishes on the top rack do not get cleaned. Dishes on the bottom rack are fine.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Jan 06, 2011 | KitchenAid Dishwashers
Bottom sprayer does not clean or work, all items on bottom are the same as put in. Top is fine. runs through whole cycle.2 hr 29 min
Check the free rotation of the spray arm. If arm jets are clogged clean them.
After placing the dishes see to it that, the arm is freely rotating without any obstacles.
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
7-8 year old KitchenAid washes dishes on bottom, but not on top
Position the spray arms in a certain position. Activate the dishwasher for a few seconds and then examine the position of the spray arms. If the upper spray arm has not moved, then either there is no water coming to the spray arm or the spray arm is clogged.
Apr 14, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwasher Not washiig properly suspect upper spray arm is
the most common problem is low water pressure.when you start the dishwasher check the amonut of water in the bottom of the dishwasher there should be about an inch of water in the bottom.
if needed add some more water to the unit and see what happens this can determine if the fill valve is bad,or the control board.if the unit washes change the fill valve or check your water pressure,if there is no change then the main wash motor needs to be change because it is not putting enough water through the system to properly wash.
Feb 24, 2010 | Dishwashers
Later LG model, I don't remember # upper arm doesn't spray/rotate, just trickles water
The Lg D/washers normally have a fascility that allows one to choose either the upper arm or the bottom arm or both to run as you choose. there is an actuator that can stick which would cause this problem. Otherwise simply, your rotor needs a good clean.
Sep 24, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Apr 14, 2009 | Siemens Dishwashers
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
LG 24" XL Tall Tub Built-In Dishwasher - White Logo
553 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
