Question about Maytag Neptune MAH5500B Front Load Washer
Smells moldy and very loud during spin cycle - Maytag Neptune MAH5500B Front Load Washer
    Novelist:
  • 77 Answers
The moldy smell is a typical problem from these front load machines. This happens due to the design of front load machines themselves, and the rubber "boot" or gasket at the front that seals the machine when the door closes. Since these machines use less water, they do not flush out the dirt and gunk as well as typical top load machines. Plus, the gasket at the front that seals the washer door holds water even after the cycle is over. This water tends to linger and start to mold and stink. Remedies are few. After washing, leaving the door cracked and/or opened will help keep air flow and dry out the tub quicker. This helps with preventing the stagnant air. Unfortunately, you are experiencing the smell.
There is a product called Affresh. This is like an Alka seltzer tablet for the washer. The directions are included on the packet. As far as I know there are 3 tablets to a pack. Essentially, you run your washer on the hottest cycle possible (or a clean cycle if your washer has that) and toss in the tablets. Preventive maintenance can be performed by cleaning your washer monthly (or as needed) with a tablet at a time. When you have the smell and need to get rid of it, it requires more of a kick. In that scenario you would use all 3 tablets. These tablets will kill the lingering bacteria in the washer and hopefully all the smell. You may have to rinse and repeat this method.
On to the loud noise. Noises are hard to know unless actually heard. But I have a good idea what you are experiencing. If it is a very loud ROAR, kind of like a plane, that is a tub bearing in the back of the machine. This is a VERY costly repair, both for labor expenses and parts. The parts will run you between $200 and $400. Once a repair man can get in and see which parts have failed, then you will know. Also, it depends on what that particular repair man will charge. As unfortunate as it may seem, I would not recommend fixing it. This will save you money from the repair man spending 1-2 hours ripping it apart to tell you the final bill will exceed $500 or $600 dollars.
If this is not the sound, describe it and I can offer more assistance :)
Posted on May 28, 2010
I have a 2012 top loading frigidaire gallery washer. It recently started making a loud thumping noise during the wash cycle. When it spins out it smells like burnt rubber. Any ideas? Thanks
There is a rubber belt between the motor and the rotating cylinder.
If it is frayed, then part of the belt is hitting something during the "wash" cycle, and rubbing much faster during the "spin" cycle.
Replace the belt.
Aug 27, 2015 | Frigidaire Washing Machines
Neptune MLG2000A doesn't drain completely and has moldy smell
You need to clean the stationary "brush" that collects lint and debris from the water during the cycle. The brush can be seen around the tub directly touching it along the bottom/front of the device. Right were I pour my detergent in, after the cloths are in there. To remove the debris I use a bottle brush. You can expect to use trial and error for your attempts. As far as the water being left.... My device has always left water in the bowl. I periodically just run a cycle with no cloths and bleach...HOT.....Mine is not spinning at the moment...again....I think its another call to the local dealer....AGAIN....
Jun 11, 2010 | Maytag Neptune MLG2000A Front Load Stacked...
Moldy smell in dryer
remove the front and top covers and remove drum belt then drum and vacuum and wash out all lint that couldnt get out during your vent being plugged then leave it apart and fan dry it out thoroughly and put it together
Oct 04, 2009 | Dryers
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
Not enough water during wash cycle causes clothes
Yes i fixed the problem. If you want the solution then you can send me the fee you charge others to fix their problem.
Aug 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Loud noise on Spin Cycle
CENTER SUPPORT BEARING IS BAD. VERY COSTLY IF NOT UNDER WARRANTY USE FOR BOAT ANCHOR. GOD KNOWS I HATE TELLING PEOPLE THAT. SORRY, FXIT
Oct 11, 2007 | Admiral AW22 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
278 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
