Question about KitchenAid KSB3 Classic Work Top Blender
Blender stopped working
This blender has worked perfectly for several years. Today when I turned it on there was a loud humming and the motor ran unevenly for perhaps 10 sec. I turned it off and it would not turn on again -- no humming sound or any response. I checked the outlet with another appliance and even tried another active outlet. Still no response a hour later. Any suggestions? Where can I find a service manual to see how to disassemble? Thanks, John
SOURCE: Blender base gear knobs broke off
http://www.fixya.com/support/t509590-kitchenaid_ks85_coupling_drive
Reports the same problem and a couple of solutions.
Posted on Sep 26, 2008
  • 9 Answers
SOURCE: blender blinks
need to resolder the triac located on the Printed circuit board this part is on an aluminum heat sink, and the third leg is most of the times the one with a broken or poor soldering joint due to the vibration of blender
Posted on Nov 03, 2008
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
  • 145 Answers
SOURCE: the rubber gear that turns the blade in the
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Posted on Jul 07, 2009
  • 145 Answers
SOURCE: Blender won't work
This indicates an internal problem with the blender itself as pertaining to the motor. I would suggest contacting Kitchenaid Customer Service to see about having the blender repaired or possibly replaced.
Their toll-free phone number is 1-800-541-6390.
Also, a listing of Kitchenaid certified repair facilities may be found at the following link:
http://caservice.kitchenaid.com/
Posted on Jul 08, 2009
Looking for black and decker 550w 5 speed blender owners manuel
Try Googling (Black & Decker)(550w)(manual) without parens.
Jun 22, 2017 | Blenders
Kitchenaid blender motor loud hum not working
Can you check it without the beaker on? It could be the blade seizing up, how free does it turn by hand?
Dec 02, 2012 | KitchenAid KSB560 5 Speed Blender
I reveived the 48952 food fusion 2 years ago, used it twice and put away as I had another one. I took it out of storage today but it won't work. I have tried all the attachments and no attachment but the...
Plug something else into the electrical receptical to verify you have power from your outlet. Then remove bottle and blade assembly; and press the two small black micro-switches inside the base of the blender. If your blender still won't turn on then you may have a faulty motor or motor connection.
Dec 20, 2017 | Morphy Richards Food Fusion Hand Blender...
The blades stopped turning in the middle of blending a batch of hummus Its is a Kitchen Aid blender about 10 years old
Does the motor still work if you take the pitcher off of the base? If so, the rod that's in the blade assembly is probably corroded. The blades are connected to a metal rod that passes through a brass tube through to the piece that makes contact with the motor when you put the pitcher on the base. The grease wears down eventually and if you don't pulse and run the motor for a long time at once, the heat can corrode the bar and cause the blade to stop spinning. You can either disassemble the blade unit, or buy a new blade unit online. google blender parts and you can get one for $10
Dec 22, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender suddenly stopped working while in use, lights are on
The motor has burned out. Check with the manufacturer about warranty status for the blender or exchange it.
Jun 23, 2009 | Kenmore 204101 Single-Speed Blender
Blender turns off
I work for Black & Decker appliances and have more than 10 years experience with small appliances.
Anytime you smell something burning while using an appliance that isn't suppose to heat food, something is wrong. You shouldn't smell any foul odors emanating from a blender. The fact that it shuts off while pureeing something as simple as oatmeal indicates that particular blender is defective.
If you contact the manufacture they will be able to inform you as to your warranty eligibility.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jun 18, 2009 | Vitamix 5000 Work Top Blender
Burning smell
That burning smell was possibly the motor windings burning out. If the windings have burned the blender will need to be replaced. Hope this has helped you today,.......... Sea Breeze
Please let me know if this answered you question.
Feb 01, 2009 | Hamilton Beach 52250 BlendMaster Ultra...
Intelli blender will not work
Do you hear it hum when you try to turn it on?
If yes, remove the cup. Try again... if the motor runs, try moving the blade by hand. If it is seized, remove it and clean it to free it again.
If not, possibly blown windings on the motor or divider circuit (which supplies different voltages to the motor for the different blend speeds). Repair will be required in either case.
Mar 24, 2008 | Westinghouse WST2000 IntelliBLEND Work Top...
Stopped working
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Sep 01, 2007 | Black & Decker BL5000 ProBlend Work Top...
Blinking lights on KitchenAid blender
Alternating blinking lights on a Kitchenaid blender indicate a bad circuit board which is unable to run the motor properly. Unplug the blender, take the jar off, and turn the spindle by hand. Then plug it back in. If it does not work properly, try a different outlet (perhaps not in the kitchen). If nothing works, the blender needs to be repaired.
Aug 27, 2007 | KitchenAid KSB3 Classic Work Top Blender
KitchenAid KSB3 Classic Work Top Blender Logo
141 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
