Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
There's a buzzing when I turn my ML100thb Intermatic Malibu power pack on.
  • 2,841 Answers
Some buzz is common in most low voltage power packs. Yours may be overloaded. It is a 100 watt power supply. That means you can only connect five 20 watt bulbs, ten 10 watt bulbs, or twenty 5 watt bulbs. Also this must be on very short runs of low voltage wire. If you use these on a long run, like 75' or more then you need a much heavier wire. Lamp wire works well. A short or loose connection anywhere in the wiring will also cause the transformer to buzz. Sometimes they just buzz and your only solution is to replace it if the noise bothers you.
Posted on May 28, 2010
  • mayj6 May 29, 2010
    I am using a 35 watt bulb only with a 50 foot cord. So, I don't see why it would be buzzing loudly. Also, the light isn't working, so I'm afraid I'm doing something wrong. Are there any other issues it could be?
  • NOT ME May 29, 2010
    Just make sure you have it connected properly with the two wires not touching each other. Sounds like you nay have a short in the wiring. Connect the light to the power supply with a known good short 2' piece of wire and see if it works as it should. If so, use a multimeter to test your 100' run of wire to see if it is shorted which I suspect is your problem. Disconnect the wire at the transformer and at the light. Now set the multimeter on OHMS and with one end of the wire disconnected and the 2 wires not touching each other check across the other 2 wires at the other end of your 100' run of wire. Red probe on one wire and black probe on the other. If you get a reading on the ohm meter the wire has a short in it. Replace the wire or find the short and repair it.
Rotating dial no longer turns. lights come on ehrn rotated manually.
You posted under Malibu power packs:
Open following link for troubleshoot steps, manuals, warranty information:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If timer dial is no longer rotating, the clock motor is bad.
There are no replacement clock motors for Intermatic/ Malibu.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Work around problem: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
Apr 16, 2011 | Malibu Hardware & Accessories
After a power outage how to reset timer correctly
You posted under Intermatic or Malibu power packs:
Different brands and models re-set differently.
For full information on Intermatic/Malibu power packs showing links to Malibu and Intermatic manuals, plus troubleshooting, and trippers and tips:
Oct 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Timer on my 200W transformer is working but lights will not turn on manually or by timer. when i turn on with manual switch they flash on for a second then turn off. i am just under 200W for total...
You posted under Intermatic-malibu power packs.
Wattage of bulbs must match wattage of power pack or bulbs and power pack will burn out.
Your power pack might be damaged beyond repair.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Aug 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
The timer wheel turns counter clockwise how can I fix
There are no replacement clock motors.
Improvise by setting timer to override and plug power into cheap plug-in timer.
Jun 24, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Clock does not work,manual operation turns light on
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
Jul 11, 2010 | Malibu ML200RT - Low Voltage Power Pack...
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
I have a Malibu 600 watts low voltage transformer that works only for 30 minutes and then, will turn on again for another 1 hr. I only want to turn on one time but for 4hrs. I already removed one red and...
If problem timer malfunction, then set power pack to override, buy cheap plug-in timer, and plug power pack into cheap timer.
If problem is internal wiring, then replacement is option.
Sep 01, 2009 | Intermatic Malibu 300W Power Pack...
I am having trouble reading the directions for setting the timer (Old Eyes). Please e-mail this information. Thank you.
1) I cannot see a model number posted with your question.
You posted under Intermatic/Malibu power packs.
2) Power pack manuals can be downloaded at following links:
http://malibulights.com/customer_service/owners_manuals.aspx
http://www.intermatic.com/products/professional%20lighting/light%20expressions/power%20packs.aspx
3) Download pdf manual and then use magnifying glass icon on top of pdf reader page to see print larger.
4) For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Jun 27, 2009 | Intermatic Malibu 300W Power Pack...
What timer motor fits in Intermatic ML121RT Power Pack ?
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
Apr 11, 2009 | Intermatic Malibu 121W Power Pack...
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
154 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
jdthefixer
 Kenneth
Kenneth
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
