Question about Canon CFX-L4000 Plain Paper Laser Fax
I am getting rec.paper jam no paper jammed though
  • 1,219 Answers
Open back door, clean feed roller very well, and open and close upper cover.
Posted on Jun 25, 2010
Cannon IR 1600 Rec paper jam message.no any paper find. how can i solve this problem?
Yes, often it is not a paper jam but a fail of paper to feed out of the tray which the machine thinks it has a jam. Clean feed rollers with Windex, or alcohol. Check the paper tray to see if paper size panels are set to the correct position. portrait, landscape, width length ect.. Good luck.
Jan 08, 2016 | Cannon Office Equipment & Supplies
Prompt says, "REC. Paper jam slide platen left". We have done as instructed and looked for paper jams with every opening. We have also rebooted the copier but turning off, then on and also by unplugging...
Hi With this copier I find the paper jam is always in the fuser area. Its very hard to get to. You need a a flash light and tweezers to get it. You need to look where the paper comes out. Thank you, Steven 805-520-3003
Oct 14, 2010 | Canon imageCLASS D661 Digital Printer
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Display says rec.paper jam,slide platen left
in service mode manually recheck all paper transport sensors...
Mar 17, 2009 | Canon Office Equipment & Supplies
Normal 0 I suggest you get a sheet of Card Stock (Heavypaper) and place it in the feed way. Then press the printbutton applying a slight amount of pressure on the Card Stock so itwill feed through the printer. The reason for this is in some cases Ihave been able to clear the paper track of debris that was deposited thereover time.
Worth a try, as I have fixed a number of printers thisway, saving costly repairs.
Hope this helps. Bud
Jan 27, 2009 | Canon Laser Class 8500 Printer
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Ir 1600
That code indicates a laser problem. You can check the door switches on the front of the machines as well as the left lower door.
Jan 25, 2008 | Canon imageRUNNER C3200 Copier
Rec . paper jam
This means your rollers are either dirty or damaged. The same thing happened to my Lexmark printer and they told me to clean the rollers. Nothing happened it still was messed up so they just sent me a new one...
Dec 13, 2007 | Canon FAX-L350 Plain Paper Laser
Canon CFX-L4000 Plain Paper Laser Fax Logo
162 people viewed this question
old marine
old marine
