Question about Briggs & Stratton Briggs Stratton Portable Generator6250w Surge
NO GENERATOR OUTPUT BRIGGS AND STRATTON MODEL 09719-3
THE GENERATOR IS A GENERAC 5000 WATT. I HAD A BAD BRUSH BLOCK AND REPLACED IT BUT NO HELP. I TOOK SOME RESISTANCE READINGS OF THE STATOR AND ROTOR WHICH ARE LISTED BELOW. ARE THESE IN SPEC??
ROTOR 26.2 OHMS
STATOR RED/BLUE .4 OHMS
STATOR BLUE/GRAY .7 OHMS
GRAY/RED .5 OHMS
  • erikcm79 Aug 10, 2010
    Need to know model number and revision # if any. To properly answer that question.
2 Suggested Answers
  • 905 Answers
SOURCE: I have a generator that does not produce any
As long as you have continuity through the stator and rotor windings, and no continuity from the windings to the core, you should be good.
If the brush block was replaced due to it being defective, take a look at the diode and capacitor regulator as well. Using a multimeter, the diode should indicate continuity in one direction, infinite resistance in the other. If you get this, then replace the capacitor. If not, then replace the diode, and likely the capacitor as well.
Posted on Jun 12, 2010
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
    No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
    Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
    Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
    Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
    If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
    May 13, 2014 | Briggs & Stratton Briggs and Stratton...
    Briggs & Stratton Briggs Stratton 6200 Watt Portable Generator voltage adjust
    Usually the cause of slightly low voltage like this is that the engine is not running at full operating RPM. Find the high speed adjusting screw on the govenor linkage and adjust the engine RPM until the output is 220V - 240V
    Dec 09, 2013 | Briggs & Stratton Briggs Stratton 6200...
    How to fix an off and on switch on a briggs and straton model series, 19e400 5000 watt, on and off switch located on top of the motor. is there a wire thats supposed to hook onto the switch somehow.
    Kill switch should have a wire connected to the tab on the spark coil under fan cover. The switch is a means of shorting kill wire to ground. On some generators, there will be another method of shutting down the engine. Usually on/off switch will be more visable on the control panel. Most likely the switch on fan cover was not connected to prevent confusion.
    Sep 14, 2011 | Briggs & Stratton Briggs and Stratton...
    No power output from Briggs & Stratton ProMax 7500E generator
    You may have exciting field broken. Look for a fuse or wire break.
    Jun 04, 2010 | Briggs Stratton Portable Generator 305cc...
    I have a generator that does not produce any volts. I replaced the brush block because it was bad with no help. I took resistance readings of the rotor and stator. Are these in spec?? briggs and stratton...
    May 28, 2010 | Briggs & Stratton Electrical Supplies
    I have a Generac portable generator 5000 watts, won't start!
    I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
    May 08, 2009 | Electrical Supplies
    I have a Briggs & Stratton Generator 5550Watt model 030253 That is showing an output of only 4.6 Volts at the pannel. Suggestions???
    Check to see if this unit has brushes and rings. If it does, then make sure that the brushes are making a good contact on the rings. If the contact is good, then your voltage regulator could be bad. This would require more troubleshooting.
    May 04, 2009 | Briggs & Stratton Power Products 5,550...
    Briggs & Stratton Briggs  Stratton Portable Generator6250w Surge Logo
    628 people viewed this question
    Top Briggs & Stratton Electrical Supplies Experts
    John Trevino
    Falcon52
    Level 1 Expert
    Craig Butler
    Craig Butler
    Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
