Question about Maytag Neptune MAH5500B Front Load Washer
After a winter the washer at a beach house won't start. Everything seems OK but the unit won't start a wash. Any way to " reset" the washer?
  • 10,319 Answers
Check out this website that has troble codes lited for your machine
It may prove to be very useful for your problem
http://www.applianceaid.com/neptune8.html
Posted on May 29, 2010
Front loader won't start on certain cycles
Hello sidneyskiss - From what you have described if only the normal cycle is working, then there seems to be a communication problem coming from the main control board or wiring failure. Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart washer. If it proves to be ineffective, I would suggest contacting a professional technician to move forward accurately.
Jan 08, 2013 | Frigidaire GLTF2940ES Front Load Washer
Front load washer stuck on final spin
What is the complete model number of your unit?
Dec 10, 2012 | Washing Machines
Frigidaire FEX831CS Top Load Stacked Washer / Dryer dryer won't start
Hello - Try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and start normal cycle. If this proves to be ineffective, then contact a professional to move forward accurately. Possible causes could be a faulty power cord or house wiring, defective control board, thermal limiter or door switch.
Oct 22, 2012 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
When pressing start on my frigidaire washer LTT2940FE1, It says pause and won't start.
Reset the unit at the household circuit breaker and retry. PAU means the unit is paused either by a blockage and the sensor won't let the unit continue, or it was manually paused by a button press.
Jul 26, 2012 | Frigidaire ATF6000ES Front Load Washer
Took washer apart, put it back together and now it won't start
ok... seems that it is trying to fill but wont...first...for all problems after dis-assembly of anything...I always recheck all wire connections...yould be amazed how a wire can be pulled off and you not notice it...next...if they are all tight...next ensure your water supply is turned back on at the faucet....try unplugging the unit from the wall, waiting 5-6 mins and plug it back in..to see if the controls reset..phillip
Jul 04, 2012 | Bosch Nexxt Premium WFMC6400UC Front Load...
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer power is on, everything seems to work but the water won't come on at all, then all the lights start flashing.
If i got you Correct - Water is not entering the Washer? Am i Correct?
OK,
Few more Details :-
1. Make and Model of the washer?
2. How old the unit is?
3. Any Smell, Noise or Error Message?
4. Any Sequence of Blinks?
Thanks!!
Jan 10, 2010 | Kenmore HE2 Plus Front Load Washer
Laundry
Same problem with my front loader. You have to make sure to clean out the rubber trap in the front regularly. it seems to collect alot of hair and plug the drain hole. also it helps to leave the door open when you finish washing to further reduce the stagnant water smell. Use fabric softener for the towels!
hope that helps.
Aug 02, 2008 | Kenmore Elite HE4 Electric Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
57 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
