Question about AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90
A O Smith insulated pool pump runs when turn on and is pushing water but it has a high pitched hum. Was running ok when pool was closed for the winter. I am afraid to leave it run, don't want to blow it up completely. Is there anything that needs lubed? Any other suggestions as to why it seems to be running so hard? Thanks
  • 3,289 Answers
Check out this AO Smith Pump Motor troubleshooting guide, at the link below. You may have an issue with a start or run capacitor, but this guide will help you determine the problem.
http://www.aosmithmotors.com/WorkArea/DownloadAsset.aspx?id=588
Please rate this reply if helpful - good luck!
Posted on Jul 08, 2010
How to prime an A O Smith pool pump
if the pump is higher than the pool, you should have a ball valve at the front of the pump. close this valve, fill pump housing with water. close the system, open the valve and turn on pump. if the pump is below the pool level, you shouldnt have this problem.
Jun 27, 2014 | AO Smith Pool & Spa
The motor works sometimes but it is very hot.
It's normal for these to run a little hot, a couple things may cause your motor to run hotter than normal.
1. Bad bearings - a local motor shop can take it apart and replace them for around $50. Usually you can tell by a high pitched grinding or squealing noise
2. Wrong impeller - if your impeller is not the correct size for your HP you will be moving too much/not enough water through your pump causing stress to your motor
3. Blocked airway - you can use a can of air on your motors intake grille while it is running to blow out any clogs, if you have low airflow on the exhaust it probably means the airway is blocked
Oct 03, 2013 | A O Smith Motors A O Smith 1hp 115/230v Ur...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Need to trouble shoot a C4SL2N134 pump motor. need wiring diagram
WD40 IS A WATER DISPERSANT AND WILL CAUSE MORE DAMAGE THAN GOOD ,IT WASHES AWAY OIL AND GREASE.. YOU MUST HAVE THE START SWITCH SET ,IT SHOULD BE CLOSED FOR START AND OPEN WHEN RUNNING.. NEW BEARINGS ARE THE ONLY GOOD FIX . YOU CAN TAKE THE BEARING IN YOUR HAND AT A SLIGHT ANGLE AND SPIN THE ROTOR, YOU CAN FEEL ANY BEARING DAMAGE THREW YOUR HAND I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Jun 02, 2010 | Smith AO Pool Pump Motor
AO Pool Pump Motor: my water pump motor only hums when the pressure is...
check voltage at the motor on the two lines should read what the motor label wiring diagram is set for, kinda sounds like it may be using 115 v and motor is set for 230 ... volt meter auto parts store ask them how to use it. there cheap and a good tool to have ! it also may be a run capacitor. search you zip for your local pool pump repair guy
HEY IF I WAS ANY HELP PLEASE GIVE A THUMBS UP ... JAY YOUR LOCAL POOL PUMP REPAIR GUY IN FLORIDA THE POOL IS OPEN 365 DAYS A YEAR, COME ON IN THE WATER IS JUST FINE...Jay
May 17, 2010 | Smith AO Pool Pump Motor
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
My new AO Smith 2HP pool pump won't pump water, just hums
I'm guessing that you replaced the motor that goes to the pump, not the pump itself. You know the motor works just fine. Is the motor rotating in the correct manner(clockwise or counterclockwise) in relation to the rotation of the pump? Have you checked the pump to see if the impeller is working/rotating? Is the motor hooked up to the pump correctly, so that the motor is turning the impeller? Are all connections to the pump tight, so there are no suction leaks? Have you primed the pump and purged it of any air locks?
Aug 11, 2009 | AO Smith 2 HP 115/230V 56C Replacement...
High Ringing Noise
Sounds like it just needs lubricating. It's probably dry seals rubbing against the stainless shaft.
Bad bearings usually make grinding noises. Replacing bearings can be a DIY job, but not a teriffically simple one.
Apr 21, 2009 | AO Smith A O Smith Motors Century 1hp 115v...
AO Smith A O Smith Motors Century 1hp 115v Thru - Bolt Lomart Motor - Bv90 Logo
170 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
