Question about Brother P-Touch 1180 Label Printer
Hello! I have a Brother P TouchPT 1090, and there is way too much lead tape -- a big waste. I would like the first letter of each label I make to be at the edge. How can I adjust my P touch so there's no lead?
  • dwee1 May 29, 2010
    I reset the margins and that only moves the wasted space to one side of the label instead of two. I think Brother should supply customers with free tape refills, since their product - by design - is so wasteful and uneconomical.
  • 1,675 Answers
Hi you will need to change the margin size for this, you have to press the , (commer) to set the margin size, press function the < > arrows till you get "margin" on the screen, then press "enter" then using arrows < > select "full/half/narrow/chain prnt" move till you find that the letters line up to the end, you will still get a small amount of waste, this is because it has to have a set amount to be able to pull the tape through the machine before it starts to print...hope this helps
Posted on May 28, 2010
It isn't printing my letters on the label. I just installed a new tape roll
Make sure the new tape cassette you have installed in fitted correctly and the tape has not got caught on the metal guide.
Aug 12, 2010 | Brother P-Touch 1180 Label Printer
Too much lead on each label. Wasting tape. How do you adjust?
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
The letters are rubbing off the keys. To an experienced typist, my wife, this isn't a big deal but for me it's a huge hassle. Do they make replacement keys? This is the 2nd keyboard this has happened to.
Just Use Mechanical Keyboard For Replacement !
I Means Ordinary Keyboard Don't Have Facility to Replace Key!
I Give U A Simple Ticks For Rubbing Off!
Just Use Good Quality Plastic Cover For Your Keyboard!!
Feb 05, 2010 | Microsoft Natural Ergonomic 4000
I need help to change the tape on my p-touch 55 brother labeller
Hello. here is the owner manual http://www.ptouchdirect.com/ptouch/manual/PT55.pdf
Just look at the section entitled "installing/changing the cassette tape". Regards, Joe
PS kindly rate my answer. Thank you.
Jan 24, 2010 | Brother P-Touch 1180 Label Printer
Printing white letters with black background..
you need to select the right tape for your machine. You can't change how it prints except by changing the tape. Brother has many colors to choose from.
Jul 14, 2009 | Brother P-Touch 1180 Label Printer
Ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Apr 18, 2009 | Brother P-Touch 1180 Label Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
How do i limit the space between labels
I know exactly what you are talking about, the sad part is that I never found a fix for it. The only thing you can do is print more at the same time using a few spaces in between and cut it with scissors. There are some models that will waste over 1" on every label printed. It seems wasteful, but is keeping the machine from jamming and causing more problems.
Dec 04, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Brother P-Touch 1180 Label Printer Logo
826 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
