Question about Canon PowerShot SD600 Digital Camera
My sd600 does not turn on. i thought it was the battery, so i recharged the battery but it still doesn't turn on. What should i do?
  • Canon Master
  • 4,738 Answers
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Posted on May 29, 2010
3 Suggested Answers
SOURCE: SD600, the camera time resets everytime i turn it
There's a little battery in the camera under where the tripod mount is. Make sure your camera is out of warranty before attempting any repairs. Opening the case will void your warranty. Do this at your own risk.
1) Remove all six screws from the outside of the case.  2) You'll need to loosen the LCD panel, there are two little tabs holding the panel, and one screw up by the speaker (photo/movie/view) switch.  3) Remove the screw by the speaker, this will give you access under the LCD. Do not unhook the LCD cables.  4) Now under the LCD panel you should see a screw that connects the metal backplate with the tripod mount, remove that screw.  5) On the bottom, on the main motherboard, there's another screw holding the tripod mount in.  6) After removing the tripod mount, you should see a battery under the LCD cable.  7) On the main motherboard, gently (GENTLY) remove the large LCD cable and pull it through to the other side.  8) You should now see the battery pretty clearly.  9) Replace the battery. MS614X 10) Reverse the steps.
Posted on Mar 17, 2009
  • 561 Answers
SOURCE: my canon SD600 does not turn on at all. i even
the lens mechanismn may be jammed gently press the lens area while turning on but be careful not to force it or touch the lens itself.
once open a blast of compressed air may be enough to dislodge anyting blocking it.
Posted on Nov 13, 2009
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
Canon sd600, not turning on, just silent
Apr 14, 2010 | Canon PowerShot SD600 Digital Camera
Battery is recharged and full but camera says to replace battery pack
How old is the battery? It's only meant to last a couple years at most. If it's that age, time to consider a new battery. Fortunately, generic NB-4L batteries are very inexpensive these days. Here's some examples. Just make sure to read the buyer reviews as some generics are better than others.
Nov 24, 2009 | Canon PowerShot SD600 Digital Camera
My canon SD600 does not turn on at all. i even recharged the battery. it does not respond in any way.
Nov 13, 2009 | Canon PowerShot SD600 Digital Camera
It doesn't want to turn on for nothing i recharged da battery over nd over nd it still dont want to turn on
I would suggest trying another battery. If still no luck, I'm afraid you have a dead camera. In this case it might be worth selling it for spares on ebay etc.
Nov 08, 2009 | Canon PowerShot SD600 Digital Camera
SD600, the camera time resets everytime i turn it on. i read the manual and found out that there is rechargeable lithium battery built into the camera to save such setting. does any one know what type...
Mar 02, 2009 | Canon PowerShot SD600 Digital Camera
POWERSHOT SD600 WOULDN'T SWITCH ON
Hi , try to remove memory remove battery from partment clean contacts and assemble again .
Mar 22, 2008 | Canon PowerShot SD600 Digital Camera
Lens Error
Remove battery for a minute or two then reinsert and try
If the problem persists recharge the battery fully
Then try if it still persists then there is a possible fault and you should return it to the vendor if under warranty ot contact Canon if out of warranty
Be warned if out of warranty your likely looking buying a new camera
Jan 24, 2008 | Canon PowerShot SD600 Digital Camera
Canon ixus 60
The ixus 60 is also known as the SD600. It's actually quite a good camera. It uses the "NB-4L" battery. You'll need a charger for your camera's battery. Simply remove and place the battery in the charger and plug it in the wall. If you don't have a charger, generic ones are very inexpensive (so are the generic replacement batteries):
http://www.amazon.com/Camcorder-Battery-Charger-PowerShot-Bargaincell/dp/B000U96EW4/ref=sr_1_23?ie=UTF8&s=electronics&qid=1199121852&sr=1-23
Dec 31, 2007 | Canon IXUS V2 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD600 Digital Camera Logo
123 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
