Question about HEALTHRIDER R65 Treadmill
My belt wont rotate
I have a Healthrider R65 and everything works accept the belt will not spin...so all i can do is go up and down....been trying to find a serial number on it so i can call healthrider...but its no where to be found....
    President:
  • HEALTHRIDER Master
  • 832 Answers
The serial number decal should be in front bottom left hand side on the frame opposite the power cord. I would not worry too much about the serial number that is used for tracking their units. It sounds like the motor control board may have failed, but they may have you do a calibration to see if the board has actually failed.
Posted on May 29, 2010
As soon as I step on the belt it quits running
You will hard pressed to believe this but the walk belt is most likely bad creating too much friction. If the walk board is grooved under the belt it must be replaced. If the walk board is smooth and glossy leave it alone. I have seen this issue with a slightly used newer treadmill.
Jan 05, 2015 | HEALTHRIDER R65 Treadmill
Motor will not run, everything else appears to funtion and the motor is not the issue
There may be a problem with the LCB.
This is the board under the motor cover.
Dec 14, 2013 | HEALTHRIDER R65 Treadmill
I have a Healthrider R65, engine works wellbut when I step on it skips and stops for afew seconds my husband adjusted belt on each side but is till not going smoothly please adviceI bought from my fri
1) Lube the deck belt, this produce enough friction between deck vs deck belt, and shut down for to protect the electronic system
2) lube the rollers bearing very well.
3) Test the drive belt and replace
4) Test the motor input voltage, if there are the motor need repair.
5) test the output voltage board, for input voltage motor, if there are not the board is faulty.
God bless you
May 11, 2012 | HEALTHRIDER R65 Treadmill
Start my belt and it tries to start but immediately stops
hi, its seems like the belt on the motor has either slipped or just needs to be tightened more, best way to find out is open the front cover showing the motor, step on the treadmill and see what happens. if the motor is still spinning and the belt isnt then its the belt, check the tension if it is loose just tighten the belt. if the belt and motor are fine then its the running belt that needs to be tightened, to check this just put your hand under the belt and try lifting it, if you can easily lift its 2 0r 3 inches then its ok, but if you can lift it alot more this will need to be tightened, hope i have helped.
Nov 20, 2010 | HEALTHRIDER R65 Treadmill
Treadmill powers up but belt will not rotate
Check to see if the motor is spinning. If not spinning, then use a voltmeter to find out the voltage of power going to the motor that spins the belt. See if you can rotate it by hand.
Feb 19, 2010 | Epic View 550 Treadmill
HEALTHRIDER R65 Treadmill Logo
327 people viewed this question
Top HEALTHRIDER Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
