the drivers are not automatically installing. And when i plug it a message shows on and says USB device not recognizedthe drivers are not automatically installing. And when i plug it a message shows on and says USB device not recognized
You can't post conmments that contain an email address.
If you have Windows 7 Professional or Ultimate you can install XP mode and Windows Virtual PC on top of Windows 7 and run XP mode.Install the drivers on XP mode and you should be able to use your tablet. Virtual PC and XP mode are available free of charge on the Microsoft web site. The site requires authentification to verify that your copy of Windows is genuine.
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you sitek.com itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
according to IBM, your system doesn't support MIcrosoft windows 7,so there site doesn't have any drivers for Windows 7.
But drivers which are meant for windows vista usually work (90% of the Drivers) fine with Windows 7.
You can try those driver and note down those drivers which has compatibilty problem.You can directly checkthose drivers from their manufacturer sites according to their chipset if they have released driver for windows 7 Compatible.
Otherwise,if you are able to installed your network controller driver,then using "Driver Genius Professional" you can update the driver with the lastest version according to your Operating System.
You can download Driver Genius Professional from the link below
Is the genius maxfire g-08xu compatible with pes2013
