Question about Nikon D80 Digital Camera with 18-135mm Lens
D8o's shutter count up to end.. where i can fix it in the phils
    Champion:
  • Nikon Expert
  • 225 Answers
Hi lixia_pogs, if you are speaking about the 10,000 number the camera count, on obtaining 10,000 it will flip over then again starts at 1. Your camera will continue to work as it always has. Hope this is what you were looking for
Posted on Aug 25, 2010
How do I clear the error code C11A3?
Shutter unit defection.Press Utility key-Meter count-Check details-00000000-End and you entering in service mode,select trouble reset.The very simple method is remove the finisher/exit unit and work without.
Aug 05, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Why does my Cannon 600D Shutter stays open and doesn't work
maybee you are shooting the camera at very low shutter speed try to check the shutter speed first . if this does not resolve the problem you may need to drop the camera and the nearest service center and have you curtain checked . you might have reached the maximum shutter count and this needs replacment
May 03, 2014 | Cannon Cameras
How to reset shutter count on nikon dslr
Why do you want to reset the shutter count? Are you trying to put one over on a buyer? The shutter count is set to zero at the factory in the camera's firmware. Unless you have access to Nikon's program and the knowledge and equipment to flash it to new ROM (Read Only Memory), you are out of luck.
May 25, 2012 | Nikon D50 Digital Camera
I have a MIELE with a " F84 " falt code please help Thanks Phil
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F84 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
The motor will have to be removed be sure
Aug 04, 2010 | Miele G848I Dishwasher
How does self timer work?
Once you release the shutter button it will start to count down, at the end of 10 seconds it will take the picture.
I highly suggest using a tripod or if not a stable surface to sit the camera.
Nov 08, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
D80 LCD not responding and Focusing Issue
If you were not half-pressing the shutter button when you turned on the camera, then you may need to have this problem serviced.
LCD being unresponsive also seems like a servicing type problem.
I don't think your shutter count of 5000 is an issue as I know a lot of people with more shutter counts who do not face this issue. Its likely that the cam was dropped or exposed to the elements so it needs to be serviced
Oct 13, 2009 | Nikon D80 Digital Camera with 18-135mm...
Tie rod ends on 05 dodge durango
Hi there.... Tie rod ends are not hard to do at all. Take the tire off, you'll see the tie rod end. Take the nut off the end on the spindle side and lossen the nut at the other end. With a hammer, hit the section that the spindle end is inserted to until it pops out. Then unscrew the tie rod. Make sure you count how many turns it takes to remove the old tie rod end..... screw the new one in the same amount of turns that it took the old one to come off. this way you will have it close to what the old one was at. You will have to get a wheel alignment afterwards in order to have it all set up. Hope this helps you out.
Phil
Feb 24, 2009 | 2005 Dodge Durango
Canon EOS 20D shutter error
Hello - I figured it out. I had the exact same problem. The shutter failed and it had to be fixed by Canon. Apparently that happens after the shutter fires so many times (like a click-count on a printer). I just got my camera back and it's doing awesome now.
Feb 19, 2009 | Canon EOS-20D Digital Camera
Shutter making an extra clicking noise
timndege,
You are taking long exposures over 3 seconds, the camera does make some slight noise while the timer is going through the count down, that is normal, as long as the shutter is doing what it is supposed to do and your image is coming out (and the ones over 3 seconds also) it sounds normal. Only if it is hanging up and taking longer than the time you are describing, then the shutter should be cleaned.
randy320sgi
Jan 04, 2009 | Nikon D80 Digital Camera with 18-135mm...
505V owners please help me! 505V noise?
I don't know if it's considered "normal" or not, but my F505V does the same thing. The original in the msg above was only 2 seconds -- take a look at it and see how it compares to yours.
Sep 11, 2005 | Sony Cyber-Shot DSC-F505V Digital Camera
Nikon D80 Digital Camera with 18-135mm Lens Logo
43 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
