Question about Ovens
I have a gas imperial oven that loses temp after awhile but will return to temp again after awhile- why?
  • 327 Answers
Hello,The problem is the heating element. This is easy to check and usually inexpensive. There is a video at www.appliancehelponline.com/servicemanual.html that will walk you through testing and replacing. It may be a different model but the testing and replacement will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Thanks
Posted on May 29, 2010
Imperial icv-1 electric oven
Not sure what type of oven you are having, Gas or Electric ?
Apr 10, 2014 | Imperial ICVD-1-H Turbo-Flow Gas Single...
What causes the flame switch to cut out ion an Imperial ICVD convection oven
This flame sensor switch is a safety device that only allows the main valve to open after is is satisfied there is a pilot flame. Otherwise if there were no pilot and the main valve was allowed to open, the inside of the burner area would quickly fill with gas and pose an exposion hazard. The original capillary tube type switch is obsolete and a new electronic unit conversion kit is available. Contact Imperial tech support for more information
Apr 29, 2012 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Our kitchen uses the Imperial IVC-1 after it reaches temp it cuts off and inttermitently will not fire again unless it is turned off then back on. what in going on
Not sure if you have electronic or mechanical thermostat. However problem is likely to be in the electronic ignition sequence box (Usually a Fenwall) Also check the panel cooling fan is working, it cools the Fenwall box.
Feb 02, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
My baked goods are not turning out right. What is
Have you changed altitudes? Have you checked the actual oven temp with a regular oven thermometer?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Imperial ICVD-2-HH Turbo-Flow Gas Double...
Get f-3 code after oven on for awhile
F3 is Open oven temperature sensor circuit, to fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Jan 02, 2009 | GE JRP15 Electric Single Oven
IMPERIAL ICV-1 SINGLE DECK CONVENCTION OVEN
this is a common indication that the ignition module is probably going bad or the flame sensor is not sensing the flame on the burners. There are other, more technical issues possible but this is usually the most common. The "not restart" , if referring to the burners, is an indication that the ignition module has "locked out" the system, usually after 3 failures of attempts to light the burners.
Oct 31, 2017 | Imperial ICVD-1-H Turbo-Flow Gas Single...
ICVG convection oven shut down during cooking process
Wrench, clearly something is causing them to do what they do. Best I can give you are thinking points.
Does this happen every time?
Is there something else on the circuit that could cause undervoltage?
If the hi temp is tripping, why? Put a thermometer in the oven and see where it is.
Get the factory guy on the phone.
Dec 20, 2007 | Imperial ICVD-1-H Turbo-Flow Gas Single...
My oven won't heat to temp properly...
All the ovens should be checked out at the factory. With that said it sounds like the thermocouple is bad or not installed correctly.
Apr 15, 2007 | Imperial ICVD-1-H Turbo-Flow Gas Single...
Ovens Logo
113 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
