Question about Sony SLV-740HF VHS VCR
I am having troble conecting my vcr to tv, dvd plarer and Virgin cable box. Auto set up didn't work and I cannot tune in manually. To make matters worse the vcr thinks my video channel is channel 4 whereas it is AV1, further on viewing things through channel 4 (my only undesired option!) the picture quality is very poor - help!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 100 Answers
Try this unhook it all start over first hook the cable box up to the vcr witch would be the wire that says out of the cable box gose in to the ant on vcr the tv cable from the vcr gose to the back of the tv the dvd player gose into the rca jacks on the rear vidio audio in just match up the colors make sure all cables that screw in are snug up as it will degrade the signal if to loose then go to set up in the vcr and if it has a auto option for set up use it . hope this was helpfull
Posted on May 31, 2010
How can i tune all my sky channels to my dvd/vcr combo box
Hi sounds like the remote may be in the wrong mode , you can scan channels into the sky box or the TV/combo.
Make sure you are scanning them into the box not the combo.
Jun 14, 2012 | Daewoo Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
No signal from samsung dvd-vr375 and tv
That means the dvd (I assume you meant dvd not vcr) needs tuning to the stations. Press menu, then select the tool box icon(or setup) and select the tuning option. Select auto tune and press go(centre button).
Give it a few minutes to tune in and away you go.
Jan 02, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
How to do a manual channel tune on a Samsung 933HD TV
in every remote there is a button that leads u to the digital setup. you have 2 options in it. manual or automatic. go for automatic. rest is done automatically. good luck!
Nov 01, 2009 | Televison & Video
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Cable box, digital service, channels not appearing
connect the RF lead from the wall to your cable box then out from that to your dvd then out from your dvd to your tv. now connect a scart lead from the cable box to AV 2 on the DVD then connect AV 1 on the DVD to your TV if you have a second scart on your tv connect that to the cable box. NOW on the DVD select AV2 now whatever is on the cable box will be recorded onto DVD/VCR. Put the DVD recorder into VCR mode and set it to auto tune all the Digital Video Broadcasts. You cannot physically tune the cable boxes own channels into the DVD via RF it has to be via a scart.
Apr 27, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Troble tuning in
If your recorder is hooked up after the cable box, then it can probably only receive channel 3...the set-top box does the switching, and sends everything to the TV (and recorder) on Ch. 3
Sep 25, 2007 | Samsung DVD-HR720 DVD Recorder
Sony SLV-740HF VHS VCR Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
