Question about Olevia LT42HVi 42 in. LCD Television
No Power TV suddenly turn-off. When TV is switch on and off from the main power switch at the back, the standby light will turn on for awhile then off.
  • Olevia Master
  • 8,457 Answers
Take ur tv aparts.Ur tv power supply board,that the board where the power a/c cord plug into it.That is ur power supply board.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on May 28, 2010
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
Lg led tv has sound but no picture
suspect either a back light power board issue or main power board to back light board issue...also, is it under warranty ?
Dec 28, 2013 | LG Electronics 47LS4600 47" LED HDTV
Hello, I have a Toshiba tv - model 42XV503D which has suddenly just switched itself off and no matter what I try it will not turn back on (upluging etc). The TV is around 3 years old. If I press the power...
Hi, Check solder mounts on power switch for dry-joints, (bad solders). If none are found I would recommend replacing the switch. The contacts inside the switch will be burned out but may be loosly connected when in the ON position when you are powering up from the mains socket switch. After initial power-up, (red light, relay click) the television will draw a huge amount of current to start up which the damaged switch will not be able to handle and will open-circuit.
Bypass the switch (Not Recommended unless you are familiar with electronics) You could try this to establish that the switch is the cause
Hope this is of help to you.
Aug 02, 2011 | Televison & Video
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
No power. the t.v. suddenly turn off
Problem sounds like the power supply pcb if the tv is totally dead with no standby light. However, first check that the main plug fuse is not faulty by replacing it ro checking with a multimeter
Mar 17, 2010 | LG Televison & Video
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Akai LCT3201TD
Most failures of this nature are with dying or defective power supplies.
I service these power supplies. If you need more info, my email is jah2mil@hotmail.com
Oct 14, 2007 | Akai LCT3201TD 32 in. LCD Television
Won't Turn On....Immediately Switches To Standby
Did you get your tv fixed? It may be the Sub power supply unit. If the main supply went out it would not light the display at all. Yes it is time for th repair shop. Good Luck.
Jan 25, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Olevia LT42HVi 42 in. LCD Television Logo
173 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
