Question about Hayward H350FDN Low NOx Natural Gas Pool or Spa Heater
Hayward pool heater will fire up but wont heat the water
  • 17,970 Answers
FEw thing there:
  • The thermostat may be set too low
  • Inadequate gas supply
  • Malfunctioning thermostat
  • You are losing heat faster then you are adding it. (If the heat loss in the pool is greater than the heat input, the heater might be too small or you may need a thermal barrier). Use a thermal barrier to help prevent heat loss
Keep that the heater should resume heating automatically if the timer turned off the system. If it is on a timer, you want to make sure the timer's microswitch (fireman's switch) is hooked up to the heater, to stop the heater about 10 minutes before the timer turns off power to the pump.
Also, I suggest check the H350FDN Owner's Manual and H350FDN Service Manual for other details.
Good luck.
Posted on May 28, 2010
Hayward 100 pool heater shaking
Not enough water flow!
Either a
  • bypass valve is open all the way, and reducing water flow into heater
  • Worn/broken internal bypass - unitherm governor
  • Blockage of some sort reducing water flow, in circulation line
When something like the above is present, the minimal water flow, gets super heated really fast when heater is on and firing! So hot in fact, that the water turns to Steam Instantly!
and the steam is a very Volatile substance! Remember? It was once used to move Locomotives!
get this fixed asap!
call a pool / spa professional for assistance in evaluating your next step.
Good Luck.
Jun 23, 2014 | Hayward Pool & Spa
Value position to heat pool
turn the valves so ALL the water goes through the heater and back to the pool
Apr 17, 2014 | Hayward Pool Products Pool & Spa
Hayward H-Series Not heating water
if all burners are working correctly then put a bypass on heater plumbing open it half way to slow down water flow that will give you a higher heat rise
May 05, 2013 | Hayward H-series Electronic Gas Pool...
Hayward H300 heater runs but will not heat water
Your internal by-pass could be stuck open or the disc could be worn to the point of letting water pass too fast. Or your thermal control valve could be stuck open. These are both found in your water header going into the heater. Hope this helps, good luck.
Jul 02, 2009 | Hayward 100,000 Btu Heater For Ag Pool And...
HAYWARD POOL HEATER FIRES FOR 5 MIN. THEN GOES OUT
Sounds like it is cycling on high limit; causes are related to water flow through the heat exchanger or a faulty high limit(doubtful given the heater cycles back on). Check the internal bypass for obstructions; has anyone worked on it recently? There are usually two high limit switches with different trip temperatures; installing the wrong one could also be the culprit. Does the heater "bang" before it goes off (a sign that the water is boiling inside the tube bundle)?
Jun 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Error code 126
This is a bad thermister or heat sensor. It mounts in your water manifold and if it goes bad no error will show. The bad sensor is telling the heater that the water is to hot and it wont let the heater fire. This is a farley inexpensive part and easy to change out. With a new one it should read the proper temp and call for heat then fire the heater. Good luck.
Jun 17, 2009 | Sta Rite Sr400na Max E Therm Pool & Spa...
My heater starts and then after about 3 seconds shuts off
Either , you really don't have good pressure (below 18 PSI on filter) or your water pressure swith is defect.
Try placing your filter on "recir" and fire the heater , if it fires and stays on .....it's definitely your pressure -back wash.
hope it helps
Jun 07, 2009 | Hayward H Series Pool & Spa Heater 400k...
1 year old hayward h1001d pool heater clicking
Actually, the clicking is likely causing the shaking. Inside the manifold of a H100 is a stainless steel diverter plate that send some of the passing water into the heat exchanger and lets the rest past and back to the pool. When it breaks, you will hear a 'clicking' noise at it rattles in the water path. When it breaks, the flow to the heat exchanger is intermittent and you will begin to boil the water, causing the shaking. This situation is dangerous, especially without a pressure relief in the heater or pipe. As long as your water chemistry is sound, Hayward will usually cover this under warranty even if the unit is over a year old. Contact them to get a factory authorized repair rep out at: http://www.haywardnet.com/locator/
May 27, 2009 | Hayward H Series Induced Draft Abg 100,000...
Hayward pool heater wont stay lit
Follow the troubleshooting guide on page 36 of this owners manual. It will walk you through problem solving... http://www.haywardnet.com/products/Manuals/pdfs/Manual285.pdf
May 25, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Hayward H350FDN Low NOx Natural Gas Pool or Spa Heater Logo
131 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
