Fan will not turn on
Comfortmaker n8mpn075f16a1 combo AC/Gas Furnace
fan seems to freeze up - wait 6-8 hours, fan works again
looking for suggestions on how to troubleshoot
  • 146 Answers
You can check amp draw on the motor if it is high the motor could be going off on the over load,also check the uF with a multi meter. also when the motor stops feel the motor and see if it is really hot. if it is hot it is a sign that it is going.
Posted on May 28, 2010
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
My furnace works on ac and blows on ac but on heat it does not blow but i hear a humming sound coming from the furnace
Most furnace operating on Oil or gas will heat the combustion chamber before starting fan to prevent cold air draft at start-up, can last a minute or two. Eiter the main flame does not come on or the chamber thermostat have fail. Try to modify fan option on room thermostat from auto to on. Cold air coming out: burner problem or no more oil or gas, warm air: burning chamber thermostat problem, leave room thermostat fan option to on until repair.
Jan 02, 2014 | Comfortmaker Heating & Cooling
Comfortmaker PAT 336K00A1
Cliff, this is Teng. Look inside your furnace if there is any flashing code. If your furnace is recently installed it should have electronic control board.
Nov 10, 2013 | Comfortmaker 7.5 Ton Heat Pump W...
Induced draft gas furnace will not turn work
Check the 3-5 amp fuse on the control board of the Furnace, tell me if the fuse has a burn spot on it.
Dec 19, 2012 | Heating & Cooling
Have comfortmaker furnace. 4-yr old. used maybe 30 dys in attic.igniter failed and replaced it.lite off and it ran for about 10 min and quit.igniter still good. troubleshooting light show hearbeat.will not...
When you replaced the igniter did you touch the metal part of the igniter? If you touched it then the igniter may be bad again. I think the pressure switch may be stuck. The pressure switch is round may be plastic or silver metal, it will have one or two rubber hoses on it. Pull the hoses off the switch and blow through it to clear hose to furnace. If you furnace is a 90% efficiency model then your drain going outside may be frozen and if it is then cut the drain so that only 6" sticks outside the structure.
Jan 11, 2010 | Comfort Zone CZ-800 Heater
Garage furnace (standing Pilot) pilot stops after 30 mins.
it sounds like the afc the fan control not working could be dust on the afc
Jan 10, 2010 | Dayton Gas Furnace Heater
Comfortmaker furnace will not light!!
Make sure you have gas to the unit and the switch on top of valve is turn to on. Can you here the gas valve click? It igniter comes on and a delay and the gas valve should come on. Kill power to furnace to reset control board. Rus Let me know how it goes.
Nov 17, 2009 | Heating & Cooling
Gas furnace stopped; Thermostat to OFF;then ON after 5hrs-worked?
You have a carrier or bryant AC Coil model number and the sn says 1995 and its 5 tons and if you actually have a heat pump with the gas furnace you have what we call in the business a dual fule heatpump setup. There are a number of items that could be causing your problem. I would recomend that you first look for the relay box discribed below and if you have that put the wires at your furnace (R &W) together with nothing else on them. If it lites then the problem could be anywhere, thermostat, wiring, the control box which has about 4 to 6 relays. If it dosn't lite the furnace is where your problem is or at least one of your problems is and start there. remove anyother wires on R&W before reapplying power. Also if you have the control box below it will have its own 24v control transformer but your going around that with the test I mentiond here. Oh yes and if it hasnt been modified you'll have to keep the solid door on it to apply power to the furnace.
There are a multitude of items it could be but I believe your age furnace has an auxiliary sensor - relay assembly it is a box about 18 inches long X 6 inches square. has about 10 terminals on it. And it will look like a birds nest with all the wires going and comming out. Id have to suggest you call someone and here's what Id do if I were you. If they say they aren't sure but think its in the relay assembly for the dual fuel control ask them to call carrier or Bryant and request they talk to a service trained expert there or recomend someone. You can do this instead of paying for 2 people. Just ask them if they know about Bryant or Carrier Heatpump dual fuel setup before you tell them to come out.
The newer dual fuel thermostats around $300 - $400 plus an out door sensor about $30 will get you fixed for parts. NO more relay box needed just the out door sensor and the compatable thermostat. if this is where the problem leads. The thermostat cost will depend on if you want the program feature. If someone is home all day Id suggest you probably don't need this feature.
This should get you headed in the right direction. If it helps you please grasde me accordingly, and GOOD LUCK!
Mar 01, 2009 | Goodman GMS90703BXA Heater
Soft lockout on comfortmaker gas furnace--how can we fix this?
try turning the power off for a minute and back on and if it happens again there is a problem
Feb 01, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
188 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
