Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub cadet model 145-734-100 will not start! No voltage to spark plug. Found grounded Yellow wire that goes to safety switch. Must have been a bare wire but it still will not start. Does this model have a coil? If so where is it located?
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 142 Answers
SOURCE: cub cadet repair manual
partstree.com may have then or call the manufacture
Posted on Sep 23, 2009
rtpflh
  • 546 Answers
SOURCE: No Spark - Cub Cadet model 71 with a Kohler 8hp
check condition of the magneto,located under the flywheel
Posted on Oct 06, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
RonInFla
  • 86 Answers
SOURCE: Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Posted on Apr 10, 2010
Cub Cadet 1282. Model# 142-680-399. Will not start/turn over.Have clicking from Solenoid,changed out same thing.
Check Under Your Seat to see if your Safety Switch has A Broken Wire Or is Frayed or disconnected. They are designed Not to Start Unless Someone is sitting on it and stop if you get off. If that Wire has a Bare spot It Will Ground out and that's why The Solenoid will Engage But The Starter Will Not.
May 12, 2017 | Cub Cadet Garden
I have a cub cadet model 800 the engine turns over but have no spark to the plug
check coil for short that model shorted a lot causeing no fire check the wires on the coil look for breaks or bare spots
Jul 06, 2014 | Cub Cadet Garden
Cub Cadet i1045 turns over but won't start. New plug, fuel pump. Is it a safety switch? how can I tell?
I hate these new machines with all the safety stuff.
I bet there is at least the safety switch under the seat. If you jump those two wires together, that will bypass the possibly faulty switch and fake out the machine into thinking you are sitting on the seat. make sure the blade engagement lever is fully in the no run position. Now check for spark
Aug 25, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna kill switch
n my 79 390CR the white and yellow wires are taped off and not used.
The black and blue wire connectors plug onto the coil as you know, but my blue wire connector has a second blue wire in it.
The second blue wire goes to my kill button.
And yes, the green wire on a Honda switch would go to ground.
I believe the yellow wire is for lighting. Sorry I don't know what the white wire is for.
Hope this helps,
Jul 28, 2012 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub cadet LT1046 will not start. Battery shows 13 amp, brand new ignition switch. fuse checked good. Kohler Commodore 23 HP engine. Model yr 2005.
This is most likely a ground problem. Remove the ground wire where it goes to the battery terminal and make sure it is clean. Then remove where it bolts to the frame and make sure that end makes contact with bare metal.
May 18, 2010 | Garden
Oct 06, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Jun 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2160 PTO problem
Yes, there is a switch on the motion lever on the transmission, but there is also a relay switch that is taped to the fuse under the hood of the mower...if this goes bad, the deck will not come on
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
111 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
