Question about HTC G1 Smartphone
G1 turns off on own
My g1 is turning off on its own i have to take the battery out. it frst started when connected to anything now it is happening when i do nothing i do not understand and am gettin really frustrated please help.
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
Htc g1 problem to start-up
try xdadevelopers.com.plent info there
Apr 18, 2010 | HTC G1 Smartphone
Phone doesnt come on completely
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
Apr 06, 2010 | HTC G1 Smartphone
Blue light on top of g1
I solved this problem by booting into SAFE MODE on the G1:
Press Menu Button and Switch on the G1 Phone using Power button. (Do not release menu Key).
That Got it to turn on. but upon power down it did the same thing with blue light. So I always start in SAFE MODE. I will start uninstalling programs until i find out which one is causing problem.
Sep 11, 2009 | HTC G1
G1 keeps turning off by itself
g1 keep cutting off when im using the phone and turns it on and it cut back off and after charge phone it work right for a minute and turn back off
Jun 21, 2009 | HTC G1 Smartphone
My g1 will not charge fast like it use 2
Have you tried recalibrating the battery? To do this you use the phone until it completely runs out of battery and switches itself off. Make sure it has completely run out by continuing to turn it back on until nothing happens except a red LED coming on. Then charge it while it's off until the green LED has been on for 2 hours. Hopefully this will improve your battery life.
Jun 10, 2009 | HTC G1
Bluetooth not accepting anything
The T-Mobile G1 doesn't actually support file transfer through bluetooth :S So it's not faulty, it's just not programmed to do that. Sorry! However it should be able to find your bluetooth headset, it always finds mine. Maybe the headset is faulty?
May 27, 2009 | HTC G1
Speaker on g1 phone stopped working
Well first of, there is your warranty, but if your phone breaks after expirations, there is both an T-Mobile G1 Repair Guide and a third party T-Mobile G1 Repair Service, so there is no need to worry.
Feb 02, 2009 | HTC G1
Hi
I was trying to transfer some ringtones from old phone to G1 and facing the same problem.
And now somewhere from net I found the solution to my problem.
Although it could not be done by bluetooth, but my problem is solved now.
You can also try it. It may help you out.
> Transfer ringtones/music/photos from your phone to Desktop
> Connect G1 to Desktop by USB cable
> On the top of G1 screen it will show the icon of USB (connected)
> Scroll down from the icon and select 'copy files from computer'
> Select 'Mount'
> On desktop a massage will appear, click 'open folder & show files'.
> Copy & Paste files from computer to G1. Now your files are in G1
> If you want to set any song as ringtone press & hold that song, a menu will appear and you can select 'set as ringtone'
Dec 01, 2008 | HTC G1
HTC G1 Repair
Buying a new one would be very expensive. Go Visit HTC Repair Center located in Dallas Tx if you are local. If you are outside Dallas you can Mail-in your Phone to them.
For more information on HTC G1 Repair visit www.drcellphone.com. They are the best Cell Phone Repair Service Center in the Nation.
Oct 12, 2008 | HTC G1
HTC G1 Smartphone Logo
108 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
