Question about Dell Inspiron XPS Gen 2 Notebook
CD drive Is there any fix-all problem for a DellXPS cd drive not reading cds without replacing it? Is there a way that I can go in through the computer itself? Thanks, Chris
    Sergeant:
  • 202 Answers
Hello cgrouz,
Unfortunately, if the drive has, indeed failed, then the most cost-effective solution is to replace it.
By "go in through the computer itself...", I am assuming you mean can you open the computer in order to access the CD-ROM drive. If that is the case, the answer is yes, you sure can.
It is, however, far more difficult to access a laptop's "innards" than it is those of a desktop computer. Each model laptop is different. How to access the inside of laptops for service varies widely.
If you'd like to let me know what model XPS laptop you have or its Service Tag Number, I'd be happy to see if I can find the service manual for you or at least instructions for replacing the CD-ROM drive.
If you'd like to check on the availability of a service manual for your laptop yourself, please, go HERE and enter either the XPS model you have or, better, its Tag Number. (The Tag Number option will give you results more specific to your particular computer. The Model Number option will give you the general results for that model of computer.)
You'll then be directed to the manuals and documentation available (to the general public) for your computer.
Please, let me know if this response was a "FixYa" or "Helpful" for you or, of course, if you have additional questions, etc on this topic.
If the solution I provided you w/ resolved your problem or answered your question, a "FixYa" would be most appreciated. :)
It is best to wait until the problem has been resolved b4 scoring the experts who participated in solving your problem or answering your question.
Very often it will take more than one exchange of information between you and an expert in order to resolve your problem.
If a proposed solution doesn't work for you, don't rate it yet. Instead, post back here letting us know and we'll continue to work w/ you until we find a solution that does work for you.
Thank you
BJ
Posted on Apr 08, 2008
SOURCE:
My pioneer cd/dvd burner model DVR-110D will not write to cds it will readand write to dvds, it will also read cds but not write to cds. how can I get this fixed, my OS is WINXP PRO?
Welcome to Fixya.
Seems like you're having a software issue that prevents your system to read/run a disc when inside the operating system. I have included the official fix from Microsoft:
DVD Drive Troubleshooting
All you have to do is to click on "Run Now" and follow the on screen prompts - just remember to eject any CD that you may have inside the drive.
Please note that if this does not work, then the drive needs to be replaced. You may contact Pioneer for replacement options in case that happens.
Hope this helps and Thanks for using FixYa.
Apr 07, 2011 | Pioneer DVR-110D (0012562773964) Burner
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
My combo drive is not reading CDs but reading DVDs perfectly
a different laser is used to read CDs than is used to read DVDs. The laser for you CD reader has most likely gone out of alignment. It's time for a drive replacement.
Dec 09, 2010 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Dell Optiplex 755 machines - TSST corp L632 drive-won't read CDs.
make sure that you are closing the CD and also make sure that the cat isnt licking the dogs balls while your doing it.
Dec 28, 2009 | Dell Computers & Internet
The drive door stays open on the dvd recorder drive after attempting to close it. the drive will not read the cds. it opens up without depressing the button.
try to read carefully the description of your dvd-r may only read dvd format and not cd. their are drive indecates to reads dvd-Rw and also cd-reader.
Nov 05, 2009 | Lite On LiteOn LH-20A1P - Disk drive -...
Cd drive will not read or burn cds
Could be problem with the optic, try to clean the optic
with CD cleaner first.
And if it still doesnt work, unfortunately you should replace with
another new CD Drive.
Sep 06, 2009 | Acer (4432A-002) CD-RW Burner
Will it read?
Yes, that's what it looks like. Make sure you put this in the right section next time, though.
Jul 08, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Acer E2140 - no longer reads CDs but still reads DVDs
ok if it reads dvds and no longer cds did it ever read cds i am asuming that you have a 2 drives one for cd and one for dvd and i asume that it did read cd no you didfnt say what happen ok sometimes when the cd does not work and the dvd drive does work some time but not always either you cd drive laser is either dirty or the plug in side of the computer is off the data cable the silver and red conected to the cd and it also could be loose from the mother board or it is bad meanig you might have to replace it but first check inside the computer you have to take the cover off and inspect now after you have done that make sur you cables and power plug going in to the cd is secure and tight then put cover on back again and restart you computer and see if the cd is working now some time windows does not load all the driver for the hardware so after it is restated check the cd and if not go to the cd drive properties in the cd and see if it is enabled or working if it is and widow says it has no problems then you might have to get a cd len cleaner disc and if that dosent work then the cd drive is died and you have to replace the drive other wise you would have to go to the registry and maybe some time when you clen you registy and see if the disc is fragmented sometimes it will work i am just giving you some starting points because you did not say what you were doing and what caused this see if i knew what you were doing and more imformation i couls have toy fix it your self
Jun 17, 2009 | Acer (91.47A37.001) CD-ROM Drive
DVD/CD Drive
hi
it can't be fix your need to replace it. laptop cd/dvd drive is very compact it cannot be repaid.
Mar 27, 2008 | Toshiba Satellite P205-S6237 Notebook
Dell Inspiron XPS Gen 2 Notebook Logo
Ekse
Clive
Clive
