Question about Kohler Home
MIRA shower - buzzing noise (pump?) when in use
4 Suggested Answers
  • 171 Answers
SOURCE: mira cold feed only power shower
Hi davecross,
I'm Harvey, the Master Plumber.
Your question is:
water pressure not great would a external pump help. Depends on your situation. If you live in a house with a well pump then turn up the pressure. If you have city water and the pressure is lacking then either install a house pump after the meter or if it is just the shower you're worried about then a booster pump on the shower line is the ticket. Be aware that useing the booster may reduce the pressure at the other faucets in the house while it's being used. The house pump will not exhibit this. You will likely need a local pro to help you with installation. Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you, Harvey, your Master Plumber
Posted on Sep 10, 2008
  • 34 Answers
SOURCE: shower goes cold after 5 mins
Sounds like you have got some elements out in the unit or you need to turn the heat up.
Posted on Feb 05, 2009
  • 34 Answers
SOURCE: does not stay hot long goes cold after 5 mins in my mira shower
This sounds like the elements or you just may need to turn the heat up. If it under two years old call the manu on the warranty. They make a good product so they should help you. I would check the heat setting first, though I doubt it is going to be the prob.
Hot water not coming through on a mira thermostatik 722 shower
Shower Doctor TV: How to Service Mira 722 & Mira 723 ...
? 15:26
https://www.youtube.com/watch?v=MnTfj-8vA_Y
Jul 5, 2013 - Uploaded by The Shower Doctor
George services a cartridge inside a Mira 723 shower. ... Until I watched this, I was stuck with a half dismantled valve, no waterin the house and a .... Fresca Verona Stainless SteelThermostatic Shower Massage Panel ...
Shower Doctor TV: How to replace a Mira Excel cartridge ...
? 5:29
https://www.youtube.com/watch?v=bvng57EMQCI
Jul 1, 2013 - Uploaded by The Shower Doctor
George replaces cartridge inside a Mira Excel shower. ... Hi, I have this model of shower and turning the temperature selector to the hot side turns the ... I just got the place so cannot rule out incorrect shower installation but Im not sure if its ... to those with a booster pump in the loft how to turn off the water.
Fault Diagnosis: Support - Mira
Jan 01, 2016 | Home
My 12 yrs old house has now got excessive clonking noise coming from the internal pipe system-seems to occur every 20 mins or so-even I believe caused the fracturing of the backing plate where clamp...
Normally clonking noises are caused by loose pipework.
As the valve closes the inertia in the water bangs the pipe against the wall.
For instance in heater radiator systems it can also cause a continuous banning noise when water under pressure is pumped through it, usually in sync with the rotation of the pump motor.
Mar 13, 2015 | Home
Mira shower manuals
If you have water with head removed, Remove and soak shower head overnight in vinegar to remove hard water deposits.
Jun 09, 2014 | Home
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
Mira sport electric shower losing heat
It sounds like the heating element is going bad, needs replaced.
Dec 01, 2012 | Plumbing
I have a Mira Vie electric shower, the pull cord no longer lights up, and therefore my shower won't run. I've checked the fuse box and nothing is labelled, it's an old style fuse box. Ther
Buy a current tester( under a tender) and test if supply is going to pull cord (remove the 2screws on cover of pull cord. )Ifyou have power then it's you pull cord that needs replaced if not its mains fuse
Sep 26, 2012 | Home
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
My mira sport electric shower keeps overheating and no longer provides hot water. What shall i do? Please help...
Sounds like the heater tank is failing. Try ringing Mira Customer Service on 0844 571 5000 who have Engineers who can repair your shower at a competative fixed price
Jan 16, 2010 | Kitchen Appliances - Others
Does not stay hot long goes cold after 5 mins in my mira shower
Jan 31, 2009 | Home
Home Logo
60 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
