Question about Poulan Pro PR550N22SH 22Inch Briggs Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) ()
Poulan 550 Series push mower won't pull start
I have a Poulan 550 Series push mower, about 1 year old. Worked fine last week, went to pull start it today and the pull handle wouldn't move, feels locked up. I cheched the oil level, which is full. Any ideas? Thank you in advance.
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
Posted on Sep 17, 2010
  • 44 Answers
Take the cover off and see if you can pull it, if not you make have a broken recoil spring.
Posted on Jun 06, 2010
  • 61 Answers
Hmmmm,,and the plot thickens. Without seeing the unit, i would have to think that when you pull the engine control cable bar, its not releasing the brake that sits against the flywheel. These cables do stretch. Pull the engine cover and you will see the brake against the flywheel. Pull the engine control handle and watch and see if brake is releasing. If its not, replace the cable.
That would be my bet. I hope this is of some help.
Posted on May 29, 2010
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
Poulan won't start
check for spark then try carb cleaner behind the air filter
Mar 31, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
One year old bolens push mower, 550 series B&S
How is your compression? If it is low, your piston rings and/or the cylinder walls could be damaged and pulling oil up to the combustion chamber, which will burn oil and foul the plug. If you overfill the oil you could possibly get this also. When was the last time that you changed the oil and/or put oil in it? Do you currently have proper oil level?
Sep 06, 2011 | Briggs & Stratton Garden
I purchased a 550 series mower last year. It worked great. I used it a week ago and it worked great. Took it out today and it starts right up but won't run for morethan 5 seconds....starts right up...
Hi, remove the bowl off the bottom of the carby and clean it out. My best guess at this stage is that you have water in the bowl. Hope this helps, regards Phil.
May 25, 2011 | Poulan Push Mower
Cannot find drain to change oil.
Poulon 550 yellow 22" Briggs and Stratton. It looks like you have to drain it out the cap by tipping it. There IS no plug on mine - spent 40 minutes looking for one, and I know what both types of the plug look like. What a lousy design. This mower is a piece of junk. The valve froze a week after I got it. Never again. A headache.
Dec 13, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
I have a Poulan PRO 550 series that I just bought 4 weeks ago. It won't start. The oil is at a good level. There is plenty of gas. Everything was checked and it still won't start. I am so disappointed. Has...
There are several possibilities for not starting. Water in the gas, Carburetor jet clogged ; Spark plug needs replacing, air filter needs replacing, or you have old gas. Or if you have hit something the flywheel key may be sheared. Hope this helps.
Good day.
Oct 16, 2009 | Poulan Pro " Pro" Self Propelled Mower
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
Poulan Pro PR550N22SH 22Inch Briggs  Stratton 550 Series Gas Powered Side DischargeMulch Lawn Mower With High Rear Wheels (NonCARB Compliant) () Logo
1,220 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
