Question about Philips GoGear SA3245/37 Digital Media Player
No enciende, no quiere cargar su bateria, no funciona mi MP4 Philips GoGear SA3245
  • 11 Answers
SOURCE: Philips GoGear SA3245 - Playlists
·         Open up Windows Media Player(WMP) on your computer. To add a track to a playlist on your computer using WMP, click to highlight an item.
·         Right-click on the item that you want to add, then select Add to Playlist. A pop-up window will appear. Select an existing playlist or add a new one. Your selection is now added to your playlist.
·         Delete a track. When you do not want a track on your playlists anymore, you are able to delete it. To delete tracks and playlists, click to highlight an item. Right-click the item and select Delete from Library to delete it.
·         To Edit track information, click on a track. Right-click and select Edit. Click on the text boxes to edit relevant information.
·         Once all changes have been made, connect your GoGear to your computer with your USB cable and download the new playlists.
Posted on Sep 24, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: POR FAVOR AYUDAME POR FAVOR AMIGO AYUDAME NO ENCIENDE MI MP4 ES UN PHILIPS GOGEAR SA6045
Va a www.usasupport.philips.com - selecta "Espanol"
mira a "reparar" o RESET
Posted on Mar 28, 2008
SOURCE: philips media mp4
ola donde puedo descargar el programa para poder convertir los videos al formato de mi mp4 philips ya que se perdio el disco intalador
Posted on Nov 20, 2008
SOURCE: want to use iTunes files in my GoGear Philipps SA3245
Actually it's not me . . .
It's Yahoo Answers . . .
You will find the MP3 setting in the iTune menu bar under . . .
iTune . . . Preferences . . . General . . . Import Settings . . . Import Using: MP3 Encoder . . .
You will need to transfer the files to your GoGear using Finder . . . I tried it . . . and it does work . . .
GL HuMor
Posted on Mar 15, 2009
Kord pa 50 enciende, pero no funciona
ola claudio
tienes que resetear el organo y despues cargar el os
Dec 13, 2013 | Korg Pa50 Professional Arranger Keyboard...
Registradora casio pcr 1000
La bateria esta descargada o defectuosa o no se ha programado. que tendra que ser totalmente reprogramado
Nov 16, 2013 | Casio Parts Cash Register PC Desktop
Tengo una Toshiba Satellite A 305 S 6825. Mi problema es cuando le conecto el AC esta se apaga y enciende nuevamente indicando error. Si cargo la bateria completamente y la desconecto del AC esta funciona...
Ya que usted informa que con la batería sola funciona, pues es de pensar que el cable electrico y el cargador están defectuosos.Compre o pida a un amigo un cable compatible con su LTop y haga una prueba.Si funciona el cable esta dañado.Si no funciona entonces el socket de entrada de el cable esta defectuoso.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Computers & Internet
No puedo sacar de la pantalla MSDC, saco la bateria pero igual no enciende.
tratar de cargar la bater?a ratos no se iniciar?. despu?s de una hora intente encender de nuevo.
C?maras MSDC puedan a su vez borrado cuando las bater?as est?n bajas. sin embargo, las luces de energ?a tal vez en pie.
May 11, 2011 | Cameras
El problema es no enciende, ni la pc. lo reconoce. gracias ante mano
Try restarting your computer after connecting your player, leaving your player plugged in while you do. Pruebe a reiniciar el equipo después de conectar su reproductor, dejando a su reproductor conectado mientras lo haces.
Open "my computer" and look for the icon of the player..it may come up as "Removable disk". Abra 'Mi PC' y busque el icono del reproductor .. que puedan surgir como "Disco extraíble".
Jan 19, 2011 | Philips GoGear SA2625/37 MP3 Player
No enciende el display queda negro. La fuente y la bateria estan bien. El ventilador de la cpu funciona. parece estar todo bien pero no sale nada en la pantalla. Gracias
mi laptop cuando estoy trabajando se queda la pantalla de muchos colores y me impide seguir trabajando, y tambien sino pasa eso se queda pegada
Aug 24, 2010 | Gateway MT3422 RTL Notebook
User manual for sciphone i9
Que tal tengo un sciPhone i9 me vino con 2 baterias ,hace 20 dias que lo compre y en un momento se me agoto la bateria ,cuando lo puse a cargar , la pantalla se me ponia en blanco en forma intermitente ( se prendia y se apagaba) lo tube varias horas enchufado y no cargo, probe colocarle la otra bateria que me trajo de fabrica y empeso a cargar bien, PUEDE SER QUE LA 1° BATERIAS YA TENGA PROBLEMAS O ES QUE LAS BATERIAS QUE TRAEN SON DE MUY MALA CALIDAD, si es haci ,que tipo de bateria puedo comprar de mejor calidad,muchas gracias por su respuesta,Saludos
Aug 16, 2010 | Cell Phones
Lost CD software for philips gogear SA3245/37
i have the cd and i can make you a copy because you need it because the mp3/mp4 have a special format to use to put into the mp3/mp4 but any ways i will give you a copy for 6 dollars plus shipping and handling if you need it email me at amitahuja23@hotmail.com
Jun 27, 2009 | Audio Players & Recorders
Mi pmp carga y enciende su luz pero no quiere encender el aparato
YO TENIA UN PMP ME PASO LO MISMO. Y TEMO DECIRLES QUE MURIO, TUVE QUE CAMBIARLO, LO QUE ME DIJERON FUE QUE SE DAñO LA MEMORIA Y LA BATERIA, ASI QUE PAILA. TAL VEZ EL TUYO NO SUFRA LO MISMO
Dec 06, 2008 | iRiver PMP-140 Digital Media Player
Philips GoGear SA3245/37  Digital Media Player Logo
461 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
