Question about Epson Stylus Photo 870 InkJet Printer
I cannot turn off my printer. all lights are
I cannot turn off my printer. all lights are flashing. i tried to push and hold on - off switch! Nothing. Paper jam button . nothing! What next?
  • 973 Answers
Unplug it, wait about 1 minute and plug it back in.
Posted on May 28, 2010
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    My epson tx700 printer dispaly ink pad at end of life and printer not start
    A fix from a forum:
    Procedure 1 We found this procedure to work for the Stylus Photo 1270 type printer, and understand that it also works for the 870 range and even earlier models like the Stylus Color 740. The error is indicated on these printers by all four lights on the printer flashing. Even if you press the power switch on the printer, the lights continue to flash, and the printer does not turn off!
    1. Turn off your printer, ensuring that the print head is at it's home location and locked in place as normal;
    2. Power off the printer at the wall or by removing the power cable, for at least 20 seconds;
    3. When you restore power to the printer at the wall socket or by reinserting the cable, if the lights come back on straight away, the printer's power switch was 'on' - switch it off and return to step 1;
    4. Hold down the paper-feed button and the button with the ink-drops next to it, and then turn on the printer, still holding the buttons down;
    5. When the paper-out LED flashes, release the buttons;
    6. Press and hold the Cleaning button, until several lights flash - this will take a few seconds (i.e. then release the button);
    7. The printer will now attempt to reset, including resetting the EEPROM memory and running a short (about 10 seconds) cleaning cycle.
    Procedure 2
    2. Hold down the paper feed button only;
    3. Turn on the printer;
    4. As the paper feed light starts flashing, release the button;
    5. Immediately hold down the ink-drops button for some 10-20 seconds or until the printer springs into life;
    6. Allow printer to complete it's processing, then turn off for a few seconds, and back on again for a newly working printer!
    Procedure 3 - for 1290 and possibly 890 printers 1290 printer with green (power / data) and red (ink / paper feed) lights flashing alternately:
    1. Switch off printer with panel switch;
    2. Switch off printer at mains switch - leave off for 20+ seconds;
    3. Hold down roll feed and sheet feed buttons;
    4. Switch on at mains;
    5. Switch on at printer panel;
    6. Continue to hold down roll and sheet feed buttons until both green and red lights flash together in synchronisation, not alternately;
    7. Switch printer off and then, after a few seconds, on again at mains switch;
    8. When red and green lights are both flashing in synchronisation, release the roll and sheet feed buttons;
    9. Press and hold down the ROLL FEED button (the one at the extreme left) and keep it down until the machine finishes whirring, cleaning etc and the green light comes on steady;
    10. Release the roll feed button and all should be well.
    Apr 25, 2011 | Epson Printer
    The ink pads are at the end if their service life.
    Depending on what type of printer you have:
    Procedure 2
    Mar 13, 2011 | Epson Office Equipment & Supplies
    Our lexmark e234 printer has all lights flashing. Last job was 30 page document which printed out fine, then all lights started flashing. We have not been able to print since. Thank you:)
    Try resetting the printer to factory Defaults. First turn off the printer, then open the front cover like if you were to take the toner cartridge out. Once the front cover is open then push and hold the two buttons on the panel of the printer and turn the printer on. Make sure the front cover is open and that you are pushing the two buttons all the lights will flash and they will stop at the very bottom light and stay solid once that happens let go of the buttons and close the cover and that should reset the printer.
    Jan 26, 2010 | Lexmark E234 Laser Printer
    Zebra prints one page then light turns red.
    TRY HOLDING THE BUTTON DOWN AND LET IT FLASH 5 TIMES. RELEASE. WHEN THE DIMENSIONS ARE AT THE CORRECT NUMBER PRESS THE BUTTON AGAIN.
    Aug 19, 2009 | Zebra LP 2844 Thermal Printer
    Printer Error Message HP AIO 6210 printer
    Hi
    If you find the lights flashing, we could try resetting the printer.I have explained the reset procedures below
    POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
    PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
    ----(for below reset cartridges must be removed out)---------
    SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
    FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    Thanks
    Riz
    Jan 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    S9000 canon printer ink tank full
    Hi
    Try this see if work for you.
    may work
    Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not, press the Power button once more.
    8. Your printer should respond as normal.
    Nov 02, 2008 | Canon i950 InkJet Photo Printer
    Error number 1700 canon s9000 printer
    knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
    Waste Ink Tank Reset
    1: Power off printer
    2: Hold Resume button then press and hold POWER, the beeper will sound once.
    3: Hold POWER and release RESUME
    4: Press RESUME twice, then release all buttons
    5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
    6: Press Power to set data
    1. Turn off printer
    1. power off Printer
    2. Push and hold resume button and push power button
    3. Hold Power button and release Resume button
    4. Push Resume button twice ( 2x ), and now release resume button and power button
    5. Green light will blinking and stop.
    6. When green light on, push resume button 4 x
    7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
    Aug 20, 2008 | Office Equipment & Supplies
    HP officejet D135 scanner and copyer
    Hi..
    if the scanner bulb is not moving, then its an hardware problem.
    We can try by resetting the printer.
    SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
    FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK/ENTER and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    (Notes - resets will take a while)
    Please let me know after resetting.
    Thank U!!
    Feb 10, 2008 | HP OfficeJet D135 All-In-One InkJet...
    Epson Stylus Photo 870 InkJet Printer Logo
    79 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
