Question about Acer TravelMate 2702WLMi Notebook
Heating up and not starting, where do I get to the fan assembly and can I blow the dust out?
    Scholar:
  • 92 Answers
Turn the unit on its back, so that when it is closed the LCD backcover is facing on the table. You'll see a smaller coverer that can be removed from the actual bottom cover. Make sure you remove the battery first then all necessary screws. Lift up the cover gently, then blow out using compressed air can. Reinstall cover and tighten with screws.
Also make sure you apply new heat sink paste to the CPU. Also make sure that the CPU Heat sink fan actually turns and is not clogged up or has bearings broken.
The older laptops like this one are easier to clean than the 6952 for example.
Posted on Jun 01, 2010
My computer will keep cutting off it mainly do it when im on netflix i thinking it got somethin to do with my shockwave
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 05, 2013 | Toshiba Computers & Internet
Tip
Laptop over heating
To reduce the effect of the heat in a laptop, a fan and heat exchanging grill are attached to the CPU. The fan pulls air into the laptop from the bottom and blows it out the back. This produces a vacuum under the laptop and draws dust into the laptop which can clog the fins of the heat exchanger. After a while, usually just as the warranty runs out, it will start shutting down, locking up or any number of other things that are not good. A really good cleaning of the fan and fins are required.
TIP: Blow the dust from the fan and fins. To reduce the dust collection, Tape a coffee filter over the fan opening on bottom of the laptop. This will reduce the dust and can be easily changed when needed, and it's cheap.
on Mar 31, 2011 | Computers & Internet
Laptop powers down on start up
Nov 29, 2012 | Computers & Internet
Not booting, no power, overheating
Aug 17, 2012 | Sony VAIO VPCEE37FX PC Notebook
The heat sink is heated when we start the pc.The fan is moving in normal speed.Then after few minutes the PC autometicaly get stopped.
Your CPU fanmay be faulty and not spinning freely, in this case replace the fan.
Check the fan and heat sink assembly and remove the dust, loosen the dust anduse a can of compressed air to clear away the dust.
May 19, 2011 | IBM (33P0825) Motherboard
When i will do some work in my pc some times the processor fan is rotating to fast and a lot of sound is coming what is the problem can u help me sir
Dear Umashankar Ji,
Don't worry this is not a problem.
This is due to overheating of processor just like we have a radiator in our Cars.
Fan starts when the car is heated up. same case with the processors and their fans.
so dont worry.
Thankyou
Gagan Gupta
Mar 21, 2011 | Intel D102GGC2 Motherboard
Cpu fan through heat wind?
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Feb 19, 2011 | Acer Ferrari 1000 Notebook
When the fan over heats it just shut down unexpectidly is it best just to buy a new fan or is there a way to solve this?
As you use your laptop, the CPU gets warm and the fan kicks in. If the CPU gets too hot, it will shut down as you have found.
Usually, the ventilation slots near to the CPU and CPU fan get clogged with fluff and dust. You need to clear this out.
Disconnect all power sources, turn the laptop upside down and remove any plate/covers that are easy to access.
Carefully blow/clear out any dust and fluff you can see, also try blowing into the ventilator slots. With luck this should clean it out well enough to keep your laptop running.
If not, you're getting into a dimantle scenario, taking more or less the whole thing apart and will neet CPU heat dispersal grease to re-assemble when clean.
Aug 21, 2010 | Computers & Internet
My T20 starts up and after a five minutes it shuts off like it was overheated
If you cpu fan is running then it is most likely overheating. Dust gets into the cooling fan and heat sink assembly reducing their ability to keep the cpu cool. You can try blowing compressed air but the best solution is to disassemble and clean it by hand.
If this has helped you please accept and rate the answer.
Thanks,Gary
Jul 13, 2010 | IBM ThinkPad T20 2647 Notebook
Acer TravelMate 2702WLMi Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
