Question about Honeywell 5804 Ademco Wireless Security watch
How do you turn off the phone ringer on a honeywell alarm key pad
Monotronics alarm key pad beeps repeatedly and read bf check bat. What does this mean
"bf" stands for "Back up failure. Your system communication to the monitoring station is working on phone lines only if it's tied into them. I would call the monitoring station and see if it's still communicating.
Dec 28, 2012 | Honeywell 5804 Ademco Wireless Security...
Security code program for ademco alarm 6150
6150 is the type of keypad you have the alarm system itself. The 6150 works on a number of different Honeywell panels. You need to locate the main metal box and open it. There should be a white sticker on the board with the panel type. (Ex. v10,v20, Vista...)
Oct 21, 2011 | Honeywell 5804 Ademco Wireless Security...
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
Sep 22, 2010 | Honeywell 5804 Ademco Wireless Security...
My lcd screen is blank and system doesn't respond to commands... Says ''not ready'' but that's it! There is power to the units but no response except a single beep after the pin and command is entered. It...
FYI 6150 is keypad model not alarm model. See if yhis helps. try pressing the " * " key bottom leftit thould then indicate zone trouble or fault. that sould give you at least some place to start.
Feb 07, 2010 | Honeywell 5804 Ademco Wireless Security...
Setting alarm to beep when doors are opened.
If it is a honeywell product enter your code then 9
Jan 12, 2010 | Honeywell 5804 Ademco Wireless Security...
How to set alarm clock
Press the lower button on the left side of the watch to enter the menu. Then press the alarm selection key (5). Use the 1 and AB keys to scroll through the existing alarms. Once on the desired alarm, press and hold the upper button on the left side until the left number on the hour starts to blink. Use the number pad to select the desired alarm time. You can scroll past unneeded number spots by pressing the lower button on the left side. When finished, press the upper left button again and you are good to go. A quick press of the upper left button will activate or deactivate the alarm. Make sure the black lines near the upper left button are visible to indicate the alarm will go off.
Dec 11, 2009 | Casio E-Databank EDB6101C Wrist Watch
ADEMCO alarm system indicates A/C not ready. What does it mean, how to fix it?
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
Nov 22, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell Ademco 128B alarm panel
You could use a vista-key module on the polling loop without using a card reader. My question is, what will hold the door shut if the strike plate is unlocked? It sounds unclear what the client wants their system to do and or what type of system they want
Nov 08, 2009 | Honeywell 5804 Ademco Wireless Security...
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell 5804 Ademco Wireless Security watch Logo
285 people viewed this question
Top Honeywell Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Honeywell Watch Expert? Answer questions, earn points and help others
