Door lock flashing on hotpoint Aquarius washing machine
I changed the door interlock but the door lock is still flashing and machine not working, however door clicks shut too, any ideas, thank you
  • 159 Answers
Look this is a long shot, but i once repaired a frontloader for a customer who was having this problem.the door lock light was showing up but it was actually the motor brushes in the motor,they where worn out & because they wern't making electrical contact the door lock light was staying on,this is stupid but the doorlock ran through the same circuit as the motor.so as a result the machine had no choice but to put up the door unlocked light.the door light must go out when the interlock closes that circuit but the motor was in that same circuit & when the motor open circuited due to the brushes the door light recognised this as an open circuit & lit up.it took me a while to work it out.Perhaps this is the same in your machine.I hope this helps you,ide be interested to know.
Posted on May 29, 2010
HOTPOIT AQUARIUS DOOR LOCK LIGHT FLASHERS
Faulty door interlock easy to fit cost parts about £15
Dec 11, 2014 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WF320
interlock is device which prevents door opening when machine is operating. why do you want to change it?
to access interlock. remove door gasket from cabinet in area of door handle and interlock is held by 2 screws from outside
Aug 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Door interlock flashing
Same issue with loose solder joint on the relays inside CCU (computer control unit)
the same bad CCU is used by several manufactures.
you have to open the CCU and re-solder the the relays to the board. they have microcracks around the legs.
you will get the door lock issue randomly.
to prove the issue open the top access panel .and pull up on the center black plastic connector and the issue will go away.
Dec 14, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius model wm62
Sounds like a faulty door interlock (quite a common problem)
UNPLUG POWER first, remove lid, remove screws holding door lock in place and lift lock assembly up, replace door lock, ensuring cables are replaced in the correct order. Refit and test.
Good luck.
Nov 11, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
HOTPOINT AQUARIUS WF250
it may be the interlock but is more probably the control PCB in the fascia, this is not a DIY repair as it requires programming when replaced.
Reagrds
Advisor
Nov 10, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
346 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
