Canon IR C3380i displays INSERT WASTE TONER CONTAINER. cleaned the one i had, will not "find" it. why
  • ladesigntc May 29, 2010
    canon imagerunner 3380i
    wont recognize that waste toner container is in.
    error light...
    wont let me use it.
    do you know anything else i can try
  • ladesigntc Jun 02, 2010
    Make sure to clean the sensor. hidden in back of where the waste toner comes out of machine. Pull out container and get in there and look for it.
    Guru:
  • 302 Answers
Most probably it is not detecting the one you cleaned. If there is any sort of circuitry or connections on the waste toner container try cleaning them with Iso Propyl Alcohol(It is nothing special). remember to clean on both sides the container side and on the copier side.
Posted on May 29, 2010
  • 1 more comment
    still wont work. how about some way to manually bypass this whole error thing.,
    im thinking the sensor unit is bad?? i dont know. just guessing.
  • Mohsin Idrees
    Mohsin Idrees May 29, 2010
    Hmmm. I f the above solution is not solving your problem then your assumption seems right. Also there can be some sort of counter in the waste container, but i personally think that maynot be the case. Any how if the sensor unit is bad It will need to be replaced. Bypassing it is above my area of expertise at the moment :).
    k. thanks for your help.
  • 493 Answers
Try to replace again to be sure it is replaced properly according to the procedures below..
When the waste toner container is full, the procedure for replacing the container appears on the touch panel display, as shown in the picture below. You should follow the instructions on the touch panel display while replacing the waste toner container.
And check the lever if it is on its original position.
Canon IR C3380i
Posted on May 28, 2010
  • 15 more comments
  • ladesigntc May 28, 2010
    i have done what it asks many times. on the copier it says
    ENTER MODE SETTINGS.
    like, its ready to go.
    but the error light wont turn off
    the start key wont light up
    across the bottom it says
  • Ibrahim OKTAY
    Ibrahim OKTAY May 28, 2010
    You shoul not replace the waste toner container before the message prompting you to replace it
    appears on the touch panel display.
  • Ibrahim OKTAY
    Did you try to restart?
  • Ibrahim OKTAY
    Try to unplug it to reset.
    It may help.
    tried all this.
    even smacked it a couple times.
    unplugged... waited reset....
    nothing.
    its like its jammed on ERROR
    i hate canon. i hate this machine.
  • Ibrahim OKTAY
    Hi again,
    Don't worry.
    You may try to reset error messages as described below:
    - Click the Additional Functions button once.
    - Click the 2 and 8 buttons at the same time once.
    - Click the Additional Functions button once again.
    - The System Management screen will open. Click the Copier button on the screen.
    - Click the Function button at the top of the screen.
    - Click the Clear button on the screen.
    - Click the ERR button to highlight it.
    - Click the OK button at the bottom of the screen.
    - Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
    - Once the unit is back up, restart the machine.
    Hope this helps.
    ok. came back today... tried this about three times... it does not work. it seems to stop it, but when i restart, error code comes back with the same original message.
    what else can i try,
    thanks lisa
  • Ibrahim OKTAY
    Ibrahim OKTAY May 29, 2010
    Normally the new empty waste toner container is raplaced with the old one. As I understand you cleaned the old one and try to replace. But while replacing, it should be saved in the device memory as "replaced" by the touch panel display and this couln't been done properly. Maybe the sensor makes problem. Please run the system monitor and see if the waste toner level is shown there or not. Then if it lets you, you can click the button "recover later". Restart the machine. This may help.
    Waiting your comments.
  • Ibrahim OKTAY
    Please check the sensor flag on the container.
    i cant see where it will say or allow me to say recover later. i looked everywhere, and it only tells me how much toner i have left, not anything about waste toner... i have seen that message where it comes up - replace waste toner container soon... but i cant get it to do that.
    it insists i replace the container. maybe the only solution is to replace with a brand new one, which i dont have. i have cleaned two of them and tried them both...
  • Ibrahim OKTAY
    And please check the cap.
  • Ibrahim OKTAY
    Hi Lisa,
    Did you check the cap?
    I think you need to replace it with a new one.
    Would you please keep me informed?
    Good luck.
    yes, i will keep you informed. i give up. no, its not the cap. you cant even get it in with the cap on.
    thanks for trying!!! lisa
  • Ibrahim OKTAY
    Thank you Lisa.
    Hope it works with the new container. (If it works, I wish you rate the solution :) )
    Best wishes.
  • ladesigntc Jun 01, 2010
    ok. heres the answer for your next person!! open up the front door, you have to unscrew the big plastic front from the copier, kind of under the toner units, and there is a sensor hidden in there right near where the toner exits from the machine into this plastic container, i think kind of behind it. ( was watching the repair guy). so, he took canned air and cleaned it...twice cuz the first time he put the machine all back together and it didnt work... so you have to clean it very very good and then the error disappeared (INSERT WASTE TONER CONTAINER) and it runs!!
    thanks again for trying to help me the other day!
    lisa
  • Ibrahim OKTAY
    Ibrahim OKTAY Jun 01, 2010
    Thanks Lisa.
  • Ibrahim OKTAY
    Did you remember that I mentioned about the sensor.
Solve this problem error code e000019-0000 is this but i can't solve this
E000019-0000 is "waste toner box full" error message. It can be reset by removing and cleaning the waste toner box.
What is Waste toner?
Some amount of toner still remains on drum even after image has been transferred to paper. This toner is not reused and sent to waste toner box instead. When waste toner container is full, E000019-0000 displays on the display panel to alert the user.
Where is Waste toner box?
Location of the container might be different for each model. In Canon IR 2200, it is located on left rear corner, just behind the cover. Dispose off the toner and clean the container thoroughly. Don't forget to clean the neck area of the bottle. After reinserting the container, restart the machine and error E000019-0000 should have vanished.
Nov 16, 2015 | Office Equipment & Supplies
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
Mar 31, 2010 | Canon (6981A002AA) for imagerunner 2200,...
E000019-0000 in cannon 3300 xerox
E000019-0000 indicates that the Waste Toner container is full.
Feb 26, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Replace waste toner container message on IR 5570
on right hand side is waste toner you should be able to dump it yourself the main problem is reseting the counter that is not included in your manual Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's
Jan 15, 2010 | Canon imageRUNNER 5570 Copier
Canon imagerunner c2880 (GPR-23)- Waste receptacle
i dont know about any counter to reset,the message is displayed when there is waste toner in the sensor window of the waste toner bottle.That window can also be cleaned.
Jun 09, 2009 | Canon imageRUNNER iR C2880 Color Copier
Canon ir 2016 problem E019
Product : imageRUNNER 2200/2800/3300(i)/2220N(i)/3320N(i) Title : E019
Error :
E019-0000 is displayed on the control panel.
Workaround :
This error code is the indication of the waste toner container being full or a problem with the detection mechanism. Actions to be taken are:1. Turn the machine off and check the waste toner container. If the container is full, empty the container. Clean the inside and outside of the container's neck with alcohol. Be sure that the neck is clear and not soiled with toner before placing it back into the machine. Turn the machine on and check to see if the code went away.
2. If the container isempty and the code is still displayed, check the neck of the container. Turn the machine off and check the container,if the neck is dirty, clean the inside and outside with alcohol before placing it back into the machine. Turn the machine on and check to see if the code went away.
3. If the machine still displays the code after the bottle is emptied and the neck clean; check the sensor, the sensor connections to and from the DC controller PCB for continuity, and the proper positioning of the sensor. Replace the sensor if it is damaged or excessively soiled with toner.
Apr 26, 2009 | Canon imageRUNNER 2000 Copier
Canon iR 2016 copier problem E019
Error :
Workaround :
Apr 25, 2009 | Canon iR 2016i Black and White Copier
711 people viewed this question
k24674
jasbo
jasbo
