Question about LG WM1814CW Front Load Washer
LG wm1814cw motor tries to turn but only moves 1/2"
No error codes, motor makes a sqeaky noise when it is trying to move moter/drum, but cant quite make it turn more than 1'2 " each direction
  • megawattz Apr 08, 2008
    Thanks, that helps! Is the stator located in the motor so the flywheel needs to be pulled to replace it or is it somewhere else?
    thanks alot applking! I got it all apart, and see how it is supposed to work- I checked resistance on the stators coils and all have continuity- I am thinking propably the little solid state circuit board attached to the stator is bad as everything looks brand new still...
  • 135 Answers
The motor or "stator" as the call it in your machine is bad and needs to be replaced.
Posted on Apr 08, 2008
  • Michael Thibodeau Apr 08, 2008
    There is no "motor" just a stator mounted to the back of the tub. Take the back panel of the machine off and it will expose it. You may want to change the rotor as well which is the cover over the stator. The one big bolt in the center middle holds the rotor on. Remove that and you will see the stator. Have fun!!!
Replaced the water pump motor, then when I went to start the washer, it wouldn't spin and I got an LE code. Repeated process several times.
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...please post back for further assistance.
Daniel
Sep 15, 2011 | LG WM1814CW Front Load Washer
We have an LG WM1814CW washer. For some reason after approx. 10 or 15 min. it will just shut off. Water and soap is still in the drum. The door will unlock and there is no error code. It just quits. We...
Hi tdld6365,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | LG WM1814CW Front Load Washer
My lg washer, wm2277hw, has the LE error code, so how do I manually make it spin to extract the water.
Hi
Daniel
Aug 27, 2011 | LG WM-2277HW Front Load Washer
LG WASHER WM0532HW, ERROR MESSAGE LE WATER INTAKE ERROR
Hi
Daniel
Aug 08, 2011 | LG Washing Machines
I have a lg tromm wm2277hb and it's not spinning. The le error code is coming on. I tried to unplug the unit and press and hold start button and then the power button for 5 seconds. Then tried the...
Hi
Daniel
Jun 17, 2011 | LG WM2277H Stainless Steel Front Load...
My WM1622FD LG direct drive washer keeps giving an error code CE, it seems like the motor tries to turn it but cant and it makes a funny noise. Is it a faulty motor? It will run the cyces when the drum is...
i find this on my washing machine also but i found that its because the load is uneven.try leveling out your load and check your suspension springs to make sure one hasnt broken loose which will make you wash load uneven.
Mar 05, 2011 | LG Washing Machines
Error reading LE. How can I fix this without calling repair guy. Washer spins but once the water is inthe machine it will not spin.
Hi
Daniel
Jan 26, 2011 | LG WM1814CW Front Load Washer
LE error code on LG washer
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps... Please post back if you need more information.
Daniel
Nov 24, 2010 | LG WM2277HBW XL Front Load Stackable...
Lg washing machine, model no. wm-1280 keep on getting error code LE, some people are saying its the sensor (which i'm dubious about) and others are saying motor or bearings....... erm help
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it’s not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn’t move freely then the motor is locked and you’ll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Sep 01, 2010 | LG Washing Machines
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
LG WM1814CW Front Load Washer Logo
143 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
