Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
I have a Weedeater Featherlite 21cc gas trimmer. It will run for approx 5 minutes then suddenly dies and won't restart. Any ideas? Thanks
  • 4 Answers
Get a new one
Posted on Jun 03, 2010
Engine was running fine and all of a sudden it started running slower until it died. It sounds like it is starving for fuel. Replaced the in line in-tank fuel filter with no effect. After it dies I will...
Check your fuel cap....try running your machine with the cap loose or off...you may have a clogged fuel tank vent... also check all the fuel lines to the carburetor to be sure none of them have degraded or have air leaks....also check your muffler to be sure it is not clogged ...hope this helps...;-D
Aug 10, 2010 | Tanaka Commercial Grade Gas Powered Hedge...
Weedeater Hedge Trimmer
It's a 2-cyle engine. The oil is in the gas.
Jun 06, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Engine Stalls out
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Poulan Pe550 Gas Edger
Weedeater won't starter
I need to replace the gas filter in a featherlite weedeater 18cc. it rotted off and I dont know what line it goes on? is the other gas line a return gas line?
Jun 22, 2009 | Craftsman 25cc Gas Line Trimmer
Echo trimmer won't start, gasoline flows out of exhaust
look at choke and air filter. ensure choke is operating and clean air filter.
May 24, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Stops running
if you bought it recenly and still able to return or exchange at store, try that first. if not, check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Sep 21, 2008 | Troy Bilt Tb70ss Gas Trimmer
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
911 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
