Question about iLO 3200 32 in. LCD Television
Letter box pic
I just moved hooked up my ILO 32" 1yr old picture has 4" of black top and bottom of picture
  • 124 Answers
You need to change the formatting. There will be a "format" or "zoom" button on the remote...or an "Aspect" button.
Posted on Apr 08, 2008
SOURCE:
I have ILO-32HD set. Wide black lines top and bottom of picture. How to remove?
Its not the set if only two channels---it does not know what channel you are on===you are describing a non problem--
May 30, 2012 | iLO 3200 32 in. LCD Television
My screen is black at da top and bottom but its a pic in the middle.its just not showing the whole picture
it sounds like you have a widescreen video on your 4:3 tv. the black bars on top and bottom widen the screen picture.
Nov 05, 2011 | Symphonic ST419E TV
Picture tube failing?
NO thats not the picture ,that is more from the vertical circuit some capacitor defect or the ic it self
hope thet will help you
regards Alan
Jun 07, 2010 | iLO 2600 Television
Parents gave me their old Mitsubishi TS-5545 a few weeks ago. Pretty sure something shook loose on the move 'cause when I finally hooked it up and turned it on today the picture is hazy and and the...
You could Start with just Cleaning Mirror and top of All 3 Tube Lenses remove Back and try cleaning out All dust and Dirt with Thin Paint Brush then Remove Front Top and Bottom Panels and then you can Clean Mirror and Top Of All 3 Tube Lenses Then Put Back Together and see what Kind Of Picture you have then! Turn Color Off on Menu See if you Have a Black and White Picture?
Jan 16, 2010 | Televison & Video
My Nikon D40X won't take pictures, only makes squishy sound
take the batteries out of the camera and the memory card..verify that the memory cards are good by trying them in a printer or another cam..
other thing is you might not be in picture taking mode..you might be in the settings mode..check the user manual if you don't know if you are.
Jan 18, 2009 | Nikon D40x Digital Camera
ILO TV
push the "Pic Size" button and make sure it is not on Panoramic, that setting stretches and warps the right and left side of the picture
Oct 22, 2008 | iLO 3200 32 in. LCD Television
Dvd player and analog tv
You're not trying to use the "Tuner" in the ILO are you? Bypass it and use the A/V cables from the "out" of the converter box. I think mine also has the coax type cable from the "to tv" to the ILO, then from the "to tv" on the ILO to the television. Either way should work. Mine works great, its a zenith and I have successfully recorded to discs in my ILO. Just change the Source back to the DVD source to watch a dvd or select the corresponding A/V connections that are hooked to your convertor box to watch/record television.
Aug 12, 2008 | iLO DVD Recorder DVDR05
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Ilo picture problem
turn off the closed caption Sounds like it's in text mode
good luck
Sue, Hitone tv, Baldwin NY
Feb 14, 2008 | iLO 2600 Television
TV picture has moved up
your pic. has shiffted vertically. very easy to fix. open the tv set, located the crt tube(end of the screen) there are four wires going down to the board that is compined in one socet. around that socet, you will find small knobs, look for vertical phase and you could adjust that pic. the adjusting should be done while the tv is on and has pic so be careful, you are dealing with a live electricity. good luck
Feb 28, 2007 | Beko 324250WN 28" TV
iLO 3200 32 in. LCD Television Logo
43 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
