Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
The tv gets power to it but when it goes to click on it clicks but does not turn on
    President:
  • 1,099 Answers
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole rerfurbish power supply board for the replacement.
Posted on May 28, 2010
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Sony Bravia LCD KLV-32U300A Symptoms: ~ powering up problem, whenever try to turn on click twice and power goes completely off no standby indicator as well. i have to discharge the stored current in the...
I know its a 32 inch TVand its probably about 2 years old, give or take. If you got a warranty on it, I suggest calling whoever you got it from (BestBuy,Amazon, etc) and seeing what they can do for you to get it fixed for free. Otherwise call Sony abotu getting a real tech out to either fix or swap parts on the TV at your house, or where to send it for repair. Depending on what it costs, you are probably better off buying a new 32inch LCD TV for about $400.
It seems you have isolated it down to the power supply though. If you are confident enough, you can get a replacement on ebay for abotu $100.
Just depends on what you value more: time or money.
May 21, 2011 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
My tv goes click click click and keeps clicking when i turn it on. I have no picture or sound
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 03, 2011 | Samsung LN46A650 46 in. LCD HDTV
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
Tv won't turn on. red power light is out
red light is on, but when the tv is turned on, it immediately shut down and goes back to the red light setting. It is like it blows a fuse or something to that effect.Post Solution
Mar 02, 2010 | LG 50PC3D 50 in. Plasma Television
LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
TV Won'T Turn On
A fuse is not your problem. this TV has a safty feture that when it senses a problem it cuts the power to prevent any fouther damage, when you un plug it the TV resets and it will turn on agian. I have the same TV Check the CRT light guns there are 3 of them. If one goes bad it will cause your problem.
Sep 22, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Clicking
problem is almost definatly power suppy related. get out your DMM and measure the voltages in the power supply. too much current to the unit may cause the exact problem you described. Carefully check all the caps in the power supply and horiz output stage for high ESR. You will need an ESR meter, or a low impedance reactance meter to check these. If not, you will have to replace the caps one by one to find the fault, if it is a bad cap.
Mar 17, 2006 | Philips Magnavox TS3260C 32" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
188 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
