Question about Toshiba MV13L2 13 in. TV/VCR Combo
The screen has narrow white lines across the top 3 inches, on cable and with a VCR Tape in.
    President:
  • 1,099 Answers
Where all colors are involved - the lines are essentially white or gray (or with a slight tint due to slight unequal settings of the color adjustments), look for something common like an incorrectly adjusted screen (G2) or master brightness/background/bias control or a problem in one of these circuits, a defective power supply or a problem in the blanking circuitry:
Screen (G2) or master brightness/background/bias control - mark setting and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
Power supply or connection to CRT neck board - insufficient voltage will result in the CRT never totally blanking. Check (usually scan derived) power supply components (from flyback).
General power supply - check B+ for correct value and ripple. A main power supply fault might result in these symptoms (and usually many others).
Blanking circuit - this may be a part of the video/chroma chip or separate. Check waveforms to determine if the blanking pulses are making it to the video output.
Posted on May 28, 2010
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
Ewd2202 dvd/vcr combo when i put a vcr tape i can
the video heads are probably dirty.there is a steel drum 1/2 inch thick that you can see if you look thru the front lid where the tape loads.the video heads are little black spec looking things on the bottom of the drum.the easiest way to clean the drum for a novice is to put isopropyl alcohol on a piece of 2 inch square paper.hold the paper very lightly against the drum with your right index finger.turn the drum from the top,anti clockwise.you will see some black stuff on the paper.do the same with a piece of dry paper.otherwise the tape will stick to the drum if still wet.DO NOT use a q tip,as it will get caught in the heads and break them.
sometimes,just running a new blank tape for 15minutes will dislodge the particles and the picture will re appear.if you have recently rented a movie,and saw lines running across the screen,and noise from inside the machine,it is damaged tape going across the heads and drum and it can wipe out the picture just like that.run a blank tape first and then clean the drum if you have to.
Jul 07, 2009 | Emerson EWD2202 DVD Player/VCR
Horizontal lines across the top 3 inches of picture
Hi
what line started? from Left to right? or from top to bottom?
Thanks!
Nov 28, 2008 | Philips 32PT6441/37 32" TV
Dark line across the top of 56HM66
I had the same problem on my tv found a simple solution its been a week and no problems so far.pull out light engine you will find round piece of tape pull it of there will be a #2 phillips screw in about 3 inches turn it clockwise and watch it vanish.i turned mine a little further to assure it would be gone.only took a couple of minutes to do dont know how long it will last though good luck
TelecomTech
jb
Oct 26, 2008 | Toshiba 42H83 42" Rear Projection...
Playback problem on SP Tapes - Top 1/3 of screen wavy lines
there are guide posts that the tape goes around, they need to be adjusted if your good at that stuff take off cover and while playing tape be careful you could damage video head.with flat srew drive . adjust right post buy turning clockwise or counter clockwise. this could be hard i hope i helped , When i first started ny video shop 1987 we started doing only vcrs.
The video head also could be bad. thanks doctor video
May 04, 2008 | Sony SLV-D350P DVD Player/VCR
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
Can not tape from cable, blue screen
If you have a cable box connected now, leave the VCR on channel 3 all the time and use the channels from the cable box.
The way this should be connected is cable in to cable box and cable out to VCR, VCR output to TV IN.
Hope this works for you.
Feb 11, 2008 | RCA VR348 VCR
Grey screen, white lines
adjust your screen at the back of tv flyback down you see the fucos and screen adjust the sreen ok
Nov 06, 2006 | Panasonic CT-36G34 36" TV
Toshiba MV13L2 13 in. TV/VCR Combo Logo
125 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
