Question about LG DLE5977 Electric Dryer
Everything electrical works it just does not want to spin
I can not get my dryer to rotate it just makes a buzzing noise when I push the start button and then stops
  • LG Master
  • 1,527 Answers
Hello there could be couple of problems 1 the belt could have snaped and 2 the capacitor next to the motor could be faulty also make sure the long that pin thats inside the door has not snaped off this clicks and makes the motor work good luck
regards
shaun
Posted on May 28, 2010
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
My Kenmore Dryer, Mdl #86681800 won't start when hot
The most likely reason it that the electric motor is failing; the thermal protector on the motor is resetting after the motor cools down. The buzzing is due to a locked rotor in the motor while it is overheated.
Another much less likely possibility is that there is excessive drag on the drum causing the motor to overheat because it is working too hard spinning the drum. Excess drag is due to worn rollers, etc.
Try rotating the drum in the CORRECT direction by hand and see if it seems really hard to rotate. You can try this on a friend or relatives machine to see how much drag is normal.
To determine which way is the correct rotation, just start the dryer, open the door and look fast! To test, just turn it in the same direction as it was rotating before it stopped.
Mar 09, 2013 | Kenmore Dryers
When pushing dryer start button, a slight buzz is
the noise is coming from the motor,if you can spin the drum by hand and it moves freely you have a bad motor and need to change it out,next time send model number and the brand name of dryer,if it doesn't spin,the belt could be jammed up or something stuck in the blower wheel,let me know how you make out
May 13, 2010 | Dryers
Maytag dryer makes an electrical buzzing noise when start button
It sounds to me like the motor is not turning, but the heating element is coming on. with no air flowing over the element, it is getting too hot. Can you operate the start switch with the top tilted up so you can see if the motor is turning but the drum is not, and just where the buzzing is coming from. Also, I would try the dryer on manual setting and on air dry to see if any setting works. Good luck
Jan 07, 2010 | Maytag MDE6000 Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
It makes a buzzing noise and will not run
Rotate the drum while holding the door button with the dryer turned on.
Apr 23, 2009 | General Electric DHDSR46EGWW Dryer
My dryer makes a buzzing noise when I push the start button
My Hotpoint dryer is seven years old and did the exact same thing. When I got over the anger and the thought of spending 4 or 5 hundred dollars to replace it I started messing with it. I finally decided that since it buzzed when I tried to start it there was current there. The only other thing it could be was the drying cycle knob.
I held the start knob and let it buzz while I slowly turned the dryer cycle knob to the right. As I turned through each cycle it would hit "off" and the buzzing would stop and then resume as I moved past the "off " setting. On the third trip around the dryer "started" and has been working since. Maybe something got out of kilter. Apparently the problem was in the knob that controls the drying cycles.
Mar 24, 2009 | Hotpoint NVL333EY Electric Dryer
When you push start button, it makes noise but won't start.
This is a A.C. hum that you are hearing. this is a warning sign. You are experiencing motor failure. the actual windings inside of the motor are losing their potential to hold an even current due to breakage. the shutdown is a safety feature built in the control panel to prevent electrical spark/fire.
Feb 14, 2009 | Kenmore 659 Electric Dryer
Dryer will not start when start button is pressed, makes a buzzing noise
open the door set the timer fo 60 min reach in while holding down the door switch give it a good spin hard clockwise and tell me what happens
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
LG DLE5977 Electric Dryer Logo
425 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
