Question about General Electric WCSR2090D Top Load Washer
There is water under the tub when the wash is over. When I move the tub I can hear water sloshing around. How can I get rid of it?
    Top Expert:
  • General Elec... Master
  • 76,164 Answers
There is always water in the tub after filling and washing, no washer can pump it all out, the leak u have is from the seal that goes on the drive shaft that drives the agitator, you will need to pull the tub out and see if the seal and the bearing for the tub are ok, I suspect you will need both and quite poss a new tub assembly.
Posted on May 28, 2010
2 Suggested Answers
Biggdex35
  • 333 Answers
SOURCE: There is water left under the tub after the wash
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
Posted on May 29, 2010
Standing water under tub in washer
Some washers don't pump out completely during the spin cycle.
Aug 16, 2016 | Samsung 4.8 Cu. Ft. Top Load Washer -...
Kenmore 2600 TOP LOADER smells like Mildew. I can hear water sloshing around under drum. Is that Normal?
The drain on all washers have this issue. Unless the drain hose runs down hill, when the pump stops, water runs back into the machine that was in the hose but was not drained.
Feb 17, 2014 | Kenmore Washing Machines
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
May 28, 2010 | General Electric WCSR2090D Top Load Washer
Is some water in the tub of a top loading washer normal?
It is normal to have residual water in the drain lines and pump following a wash cycle. This is the low point of the drain cycle and gravity will ALWAYS cause some water to be there. As long as the water is not visible in the spin basket, you have nothing to worry about.
Some model washers also have a balance ring around the perimeter on top of the wash tub that is filled with fluid. This acts as a stabilizer to help keep the washer balanced during the spin cycle. If you have any questions, please post back and let me know. I hope this is helpful to you.
Apr 21, 2010 | Whirlpool WTW5200S Top Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
The water will not drain out of the wash tub
The water drains out of the washing machine but the other day when I moved the washer I noticed that I could feel water sloshing around in the bottom of the drum but nothing is leaking on the floor.
Mar 21, 2009 | Kenmore Washing Machines
Need to drain the tub before moving
It should all be drained out of there except a little in the hose. The sloshing sound you hear in there is not old water or stored up water. It is a liquid in a balancing ring that is sealed shut but it sounds like the water is in the tub. The best way to get all the water out is to take a wet vac and **** out the water from the drain hose. Just put you hand around the 2 hoses to kind of seal it and lay it on the floor. Nothing more is really needed to move it. Just don't be too wild moving it around lol. Front load machines are usually very heavy becuase they have cement or heavy pieces to keep the basket from moving around too much in a high speed spin. Good luck
Jan 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water stuck...
There is an internal overflow hose to prevent water from getting onto the motor and other electrical components. It sounds like the overflow system did its job.
The water you hear is likely one of two things: a small amount of water that is still in the tub, under the basket, which is nothing to worry about. Or, you are hearing the fluid (that is supposed to be there) in the balancer.
Feb 21, 2008 | GE WBXR2090B Top Load Washer
General Electric WCSR2090D Top Load Washer Logo
103 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
