Question about Garden
LA145 was mowing and it stopped going forward..won't go forward or reverse..deck engages..bypass valve lever is pushed in
  • 420 Answers
Check the belt that runs from the engine to the transaxle, its separate from the belt that turns the blades. If the belt is ok I recommend you take the mower to a JD dealer.
Posted on Jun 01, 2010
I have a LT1042 hdrostatic drive and it won't go forward or reverse what is wrong
can only guess
Low on cub cadet hydro fluid?
other hydro filter other and cub cadet?
linkage came unhooked from drive mechanism
your engage disengage lever at the back of the mower is set so it can be pushed,engage lever to allow hydro pump not to be bypassed
Jul 28, 2014 | Cub Cadet Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Won't move in any gear
did the belt let go?is it a auto trans and the lever on the rear is pulled out that allows you to push it?
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
I have a cub cadet model 1420 with hydrostatic drive that will not go forward or reverse. The drive belt is moving and the hydrostatic unit was replaced 3 years ago. I still have to engage the lever to...
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
Sep 28, 2010 | Cub Cadet 46" Lawnmower Deck Drive Belt...
Have a John Deere tractor LA145 Yesterday while mowing the mower blade suddenly stopped working. Turned on and off several times with no luck All pulleys and belts seem to be intact. There was nothing...
Either you need a seat switch or the reverse switch has failed.If the deck will engage while you are pushing down the forward pedal then the rio or reverse switch is not working or it's out of adjustment.If you can not get the deck to engage at all then the problem is likely the seat switch.
May 04, 2010 | Garden
Suddenly stopped driving...
Check for a worn belt first.Then check the linkage. Next jack the unit up and try to run it forward and reverse with the engine running.If there is any movement at all in either direction then check the fluid level to see if it is up to the top.The worst case is the hydro. unit has a stuck check valve or something broken inside.Hope some of this helps. donnyb60
Mar 23, 2009 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
370 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
