Question about General Electric WCSR2090D Top Load Washer
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
  • 333 Answers
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
Posted on May 29, 2010
Standing water under tub in washer
Some washers don't pump out completely during the spin cycle.
Aug 16, 2016 | Samsung 4.8 Cu. Ft. Top Load Washer -...
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
WHEN WASH IS COMPLETE, WHEN YOU SPIN THE TUB BY HAND YOU CAN HEAR WATER SLASHING.
The pump cannot completely drain all the water out of washers. There will be some water left in the bottom of the tub that you can't see but here slosh around if you move the basket. If your clothes are not wet, this is probably normal.
Jan 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Need to drain the tub before moving
It should all be drained out of there except a little in the hose. The sloshing sound you hear in there is not old water or stored up water. It is a liquid in a balancing ring that is sealed shut but it sounds like the water is in the tub. The best way to get all the water out is to take a wet vac and **** out the water from the drain hose. Just put you hand around the 2 hoses to kind of seal it and lay it on the floor. Nothing more is really needed to move it. Just don't be too wild moving it around lol. Front load machines are usually very heavy becuase they have cement or heavy pieces to keep the basket from moving around too much in a high speed spin. Good luck
Jan 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Mother's Maytag Neptune front load washer has water left under the drum after the final spin cycle. I am not sure that this is normal. Please advise.
This is normal to hear water sloshing under the drum when machine is done washing and you spin the drum. This is part of their water balance method to help spinning procedure. I called a Maytag repair shop and they helped with my question.
Jul 23, 2008 | Maytag MAH6500 Neptune Front Loading...
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
General Electric WCSR2090D Top Load Washer Logo
833 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
