Question about ZT Group CISNET A7050 PC Desktop
Not getting sound out of my computer - ZT Group CISNET A7050 PC Desktop
    President:
  • 1,188 Answers
First you need to make sure that correct audio drivers are installed. Driver is a piece of software that commands Windows how to use the hardware.
Click here to open the support page. Input your details and register; don't worry its free. The you will be presented with an option to input your product's serial number and a list of all available drivers.
Please note that this system comes with XP and it is possible that it may not have drivers for a newer system like Windows 7. In that case let me know the model of the motherboard and I will try to search for appropriate drivers.
Posted on May 28, 2010
I am having trouble getting my sound to work on my computer, it says i have no sound card installed on my computer and i do not know how to get a sound card installed on my computer.... Please help!
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
or
you might have to get a portable usb sound card if you mean dont have a sound card installed
you might have to uninstall then reinstall both the driver and the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Dec 30, 2010 | Gateway (6000161) Sound Card
I have dell ax210 -2 speakers....I dont have the driver cd....i want the software...
Your speakers don't require any special drivers. All they do is take the analog sound signal from the computer, amplify it and play it for you. If the sound hardware is working, all you need to do is plug in the speakers. The green signal plug goes into the output jack on the computer, and you need to connect the USB plug to an open port for power. Your computer needs driver software for its sound hardware, though, and if you're trying to solve a "no sound" problem, this may be the cause.
You don't give a make and model of your computer or sound card, so I can't give you a specific link. But you can get the drivers from the computer manufacturer's site. If you have a custom-built computer or are using a separate sound card, you'll need to get the sound drivers from the motherboard manufacturer (if it's integrated sound) or sound card manufacturer.
Dec 16, 2010 | Dell AX210 2 Speakers
I am unable to get the speakers to work at all. They will not play system sounds or anything. Troubleshooter suggested that I uninstall and reinstall the speakers. So I uninstalled and went to reinstall...
I don't know what is the operating system you are using with your computer.Still we can check, first we need to find out if the problem is with the speaker or with the computer.
Try these steps
  • connect those speakers with other computer check the sound, if you are getting sound there it means speakers are ok need to check computer audio setup and hardware.
  • If you are not getting any sound connecting speakers with other computer then it is speakers need to replace.
Incase speakers are ok Disconnect the speakers
  • restart the computer,check if there is windows sound if not
  • right click on the volume control icon on the left hand button corner of the screen,uncheck the mute option.still not getting any sound?
  • try to download the audio driver from the dell support site.still not getting
  • need to check the internal speaker connection,if it is fine
  • go to this website http://www.kellys-korner-xp.com/xp_tweaks.htm and click on Restore sound -windows Audio service and run the tweak,YOU NEED TO USE INTERNET EXPLORER
  • still you cannot hear the sound change the internal speaker.
Sep 26, 2010 | Dell A215 Computer Speakers
Cant get sound
see your m powerd out put.
Apr 04, 2010 | M-Audio Delta 1010 LT Sound Card
I recenttely hooked up my old gateway compute with the boston speakers and cannot get them to work.. is there some software i need to reinstall to get them working?
on your gateway computer, check to see if you have the volume icon in the bottom right hand corner. If you do then raise the volume up.
If you don't see an icon then that means the sound card drivers are not installed and they need to be to get sound going thru the speakers.
www.gateway.com and go to there support section to get the sound card drivers. I would go there and download the sound card drivers for your computer and then just to make sure you have the speakers hooked up properly go read the manual for the speakers located here:
http://www.bostonacoustics.com/Assets/pdf/manuals/735setup.pdf
Make sure you have adobe reader installed to read the manual.
If you install the sound card drivers and the speakers are hooked up right and your still not getting sound, then that means either the sound card is bad or the onboard sound chip on the motherboard is bad.
Jan 16, 2010 | Boston Acoustics BA735 Computer Speakers
No sound, cenral and rear speakers Dell 5650 speakers
the surround sound speakers connect to the computer by way of three connectors. the system should have come with an adapter that plugs all three connectors into one green connector. if you color match that green connector into the computer you should get sound out of the central and rear speakers. not sure if the surround sound will work correctly for movies, but you should get sound
Jan 20, 2009 | Dell 5650 Computer Speakers
NO SOUND ON MY COMPUTER
i need help put sound on my computer, and where to go to download a sound device driver
Jul 04, 2008 | E-Machines eMachines Desktop PC
No sound on my computer
I bought a computer the was rebuild \. My sound is not working at all. I have been online and keep seeing a sound device or sound card is needed. I'm am not to computer savy and I have no idea what this means. Is the sound card and sound device the same? can I order the and just download so tha tI will have sound? Please help. I just so confused right now. What do I need to do so that I can hear on my computer. Even if it is through headphones?
Feb 12, 2008 | Intel Motherboard
ZT Group CISNET A7050 PC Desktop Logo
43 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
