Question about Poulan Pro 22" Self Propelled High Wheel Mower
I don't know what oil to use.
What oil do i use?
  • 284 Answers
20 oz.
sae 30 weight oil,brand name automotive oil will be good
Posted on May 29, 2010
I have a 2008 KTM 105 SX and I don't know how much
Use 50:1 ratio or 2% oil in the mixture.
That means 20ml oil for every 1000ml (1lit) of gas.
Oct 22, 2012 | Motorcycles
What kind of oil does a husky 3000psi pressure washer use?
I don't believe that Husky (Home Depot) makes any 3000psi pressure washer that operates with a 2 Cycle motor. So.... gas only in the gas tank. Husky pumps can be from several differant manufacturers... some use no oil, some are sealed and don't recommend any attempt at oil changes, and some use Non-detergent 30w oil and some use 20-50 Full Synthetic oil. You can look up your specific model specifcations with a google search for Husky pressure washer.
Oct 21, 2012 | Garden
My 05 equinox is using oil but don't see oil on surfaces where parked &no oil on engine where is it going
If you don't see any oil under or on the outside of the engine then it has to be burning it thru the exhuast due to worn piston rings or piston rings that have'nt seated yet.
Jan 14, 2012 | 2005 Chevrolet Equinox
I don't know how to oil my Janome SR 2000. Please
Oil all moving parts that you can see or can get to
Sep 13, 2011 | Janome Sewing Machines
A wrench appears and 34a I don't know what that means and I don't have the manual, it happen two days ago. I put engine oil because it showed 15% oil.
That wrench is a maintenance minder indicator lettting you know that your oil's service life is at 15%, not that the level or amount is low. Have your oil changed and have the maintenance minder light reset.
Aug 24, 2011 | 2005 Honda Odyssey
I need to add oil but don't know know what kind. I don't have a user manual George t
Most oil producers publish helpful application catalogues for their products. Some companies even dispense with technical specification and label simply "Compressor Oil" which removes much guesswork.
In the case of difficulty most larger towns will have a small company supplying all manner of hoses, pipes, seals, connectors and general trade and industrial requisites and often carrying out hydraulic repairs. Specialised lubricants are routine business for such companies.
Aug 19, 2011 | Magnum Air 2 HP 5 Gallon Twin Tank Air...
Car has oil but when he removed what he thought was the oil plug to change it nothing came out
If you don't know there the oil plug is you might want to take it to someone who knows how to change the oil
Jul 29, 2011 | Chevrolet Blazer Cars & Trucks
What level should the engine oil on loncin lx 125-2 should be
The motor is based on the Honda 50/70/90 motor. I'm not certain of the oil capacity but I do know this- The dipstick is not screwed in to check the oil level. Unscrew it, wipe it and dip it into the crankcase (don't screw it in)for the correct oil reading. Honda states oil capacities of between .8 and 1.0 liters.Should be pretty close but don't overfill it.Good luck!
Jun 11, 2011 | 2006 Loncin LX 125
If trooper has no oil will it not start
There is no safety device from keeping you car from starting up. You have a low oil pressure light on the dash that lets you know when your oil is low or there is no or low oil pressyre. So keep an eye on that oil level The best thing to do is every once in a while visually check the oil with the dip stick because no oil = siezed engine and you don,t want that. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 27, 2009 | 1989 Isuzu Trooper
Poulan Pro 22" Self Propelled High Wheel Mower Logo
95 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
