Question about Garden
I am not getting power to my lawn mower hence it will not start. I replaced the ''normal Fuses'' had the battery checked and even jumped the seat saftey switch to no avail. What is the next step? FYI its a Toro WheelHorse 267 Hydro.
  • 66 Answers
Check to see if there is a fuse inline (usually 30 amp) between engine and dash. If its blown, replace it. www.nnyparts.com
Posted on May 30, 2010
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
My Craftsman 16 hp and 42 battery not charging is it normal?
get mower started and check the charging voltage at battery. it should be at least 13.5 at battery.check cables to battery and the inline charging fuse, its located somewhere in charging system.if its charging, but battery is still dead. it could be a bad battery. or alternator. . Examine the lawn mower electrical system by starting the lawn mower up, and then removing the battery. If the lawn mower turns off after the battery is disconnected, the lawn mower electrical system is the culprit.
its a good possibility that the battery is bad if it has been in use for 4-5 years.
check the fuses first. good-day !
Oct 02, 2011 | Garden
Ingnition will not even click. Replaced iginition switch, solenoid and spark plug. Checked seat switch, transmission switch, fuse. Started motor turns when jumped. Battery fully charged. Fresh gas. ...
Hi, is the deck engagement lever off or the pto switched off? If it uses a lever check the switch on the lever. If it uses a pto check the pto switch. Hope this helps, regards Phil.
Jun 24, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Craftsman Lawn Tractor, 18 HP, 44" Cut; No SWtart!
Check the by pass switches on the seat, clutch pedal, and check the fuses.
May 15, 2010 | Craftsman Garden
Mower won't start
sounds like the ground cable is bad
Jun 03, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Engine will not crank, cannot get security alarm to reset
check the fuses for the alarm you might have blown them which would not let you start the car. word of advice never mess with car alarms and never jump your lawn mower with your car.
Sep 24, 2008 | 1992 Chevrolet G20
Garden Logo
164 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
