Question about Refrigerators
Get water, but no ice
I have verified that there is water fed to the refridgerator, but ther is no ice being made; what should done, Help!!
I have a Frigidaire FR23W3A Side-by-Side Refrigerator. The freezer is cold the water is dispensing cold but NO ice. I took the ice holder out cleaned it to make sure it was not frozen. Also chec the position of the arm. Still no ice.
Please HELP!!!
  • Anonymous May 11, 2010
    Are you getting water out of the water dispenser?
  • 135 Answers
Could be a bad water valve
Posted on Apr 12, 2008
SOURCE:
I have a side by side refridgerator freezer. I have just connected the water to the ice make / water dispenser for the first time and just a short trickle of water flows into the ice cube maker - not
I would guess that you need to purge the air out of the lines and system for it to work correctly. You can hold down the water dispenser for awhile to help, but if you do nothing, it should purge itself over the next few days.
Jan 07, 2012 | GE Refrigerators
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice works, water doesn't kenmore side by side refridgerator
HI, make sure that the lines are not frozen. This will happen if the unit is set to a temp that isn't manufacture standards. Once you have verified that the lines are not frozen, This will confirm that the inlet valve is malfunctioning. have it replaced asap.
Sep 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Fridge isn't cold
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Ice Maker
well ur refrigretor is;nt producing enough gas to produce ice make sure u hire some expert who can examin and solve it.
Mar 18, 2009 | Amana ARSE66MB Side by Side Refrigerator
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
canyou acess theice amker assy itself??
can you look intor the icemaker make sure nothings blocking ice maker from turning(ice cubed jammed in )
look into the fill tube make sure itsnot frozen
thinkin htis machin hasan electronic "eye" if so htere a trouble shoooter under the kickplate explaining the mechanism
lastly theres a white cover plate on the front of the assy. remove the cover and loook at the white gear in the center of unit. look real close at the tabsholding that gear on.MOST common causeof failure is the ice torques the main gear and those tabs snap. if htats the case , replace the ice maker assy.
Mar 17, 2008 | KitchenAid Superba Architect KSCS25INSS...
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 25, 2007 | Daewoo FR-064R Refrigerator With Ice Box
Refrigerators Logo
184 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
