Question about Fisher and Paykel GWL11 Top Load Washer
No Water Water Not Coming into The Tub, The tub is turning
  • luisa_sgro May 28, 2010
    have you checked there is water coming out of the taps? try this, remove the cold hose from the tap and see if any water is coming from the tap, put a bucket underneath the tap and turn it on. do the same for the hot tap. what water temp setting are you using? have you tried warm. has your machine got an efficiency button? is your machine the model with the LCD SCREEN? please reply with answers and i can help you further.
  • 159 Answers
Check that taps are on.if they are then you have a faulty inlet valve.most likley the cold one,verify this by trying hot fill,make sure hot tap is on.One will work & the other won't.
Posted on May 29, 2010
Only hot water makes it to the tub. I can hear cold water running. I can feel it traveling through the hose, but it does not get into the tub. Why (and where is the cold water going)?
hmm...so you're certain that the cold water is actually going in someplace huh? ok, try this...run it like you have it now...put your hand in the water flow and feel how hot or warm it is...now turn off the cold water and see if the hot water gets hotter...if it does,then try the opposite, turn off the hot water and see if there is still water coming into the tub...let me know what happens
Jun 10, 2012 | Maytag PAV2300 Top Load Washer
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
The washing machine is leaking water and it is coming from underneath the washer during all filling cycles and running cycles why?
Could be several things. Check all the hoses, water pump, water valve also check if water is coming from the bottom of tub could be tub seal. Check that there is not a leak in the outer tub somewhere I had one that had a nail stuck in one of the holes in the inner tub and rubbed a hole in the outer tub. Have fun I hope this helps.
Aug 28, 2011 | Washing Machines
I have a Fisher Paykel washer that was leaking water into tub; repair people changed cold water valve but it is still leaking; although not as much. Could it be the nozzle spray holding droplets of...
Hi just read your posting.1st try turning the hot water tap off and see if the water continues to come into the tub.If the water continues to come into the tub then turn the cold tap off.If the water stops coming into the tub after the hot water tap is turned off then you need a hot water valve.If the water stops after the cold tap is turned off then the cold water valve is still faulty.Please reply on how you got on and I will help you further.Looking forward to your reply.
May 16, 2011 | Fisher and Paykel Washing Machines
My Moen Tub and Shower have water coming out of both the tub and shower when I turn on the tub.
Take the handle back off and rotate the stem one half turn clockwise and put the handle back on.
You'll be good to go!
Mar 05, 2011 | Moen & One Handle Tub & Shower Faucet
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
Please help me I have a American Standard whirlpool tub. I have flakes coming outta the tub when the water level reaches the jets.I have bleached the tub turned the jets on, drained the tub and did the...
Are they white flakes? Sounds like you have lime deposits turning loose in the plumbing.
Was the unit purchased and installed new? Maybe the privious owner had a hard water problem.
In either case, you may have to invest in a water softener.
HTH,
Mike...
Dec 07, 2009 | Water Heaters
My upstairs tub leaked and can see large water stains on the first floor ceiling. I think it only leaks if the jets are turned on. how do you fix this?
you will want to fill the tub up and turn the tub on first and get behind the tub and see where the water is coming from. there isn't any other way to find the leak.
Oct 15, 2009 | American Standard Home
No water coming out
Clean out or replace the tube running from the water level switch in the backsplash to the washer tub. It tends to plug up with gunk right where it attaches to the outer tub. When it gets plugged, the washer can not tell if the tub is empty or full.
Aug 13, 2009 | General Electric WJRR4170GWW Top Load...
Fisher and Paykel GWL11 Top Load Washer Logo
20 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
