Question about Hayward Pro Series Side Mount Sand Filter 30" S310s
Need manuel for hayword vari-flo sad filter - Hayward Pro Series Side Mount Sand Filter 30" S310s
  • 990 Answers
Hayward vari flo valve
Does it filter? Does the pump have full prime? I'm not clear about how when the valve is put in the backwash position nothing happens.
Jun 15, 2013 | Pool & Spa
Hayward Vari-flo Xl
You have a bad o-ring at the flange... or the clamp is loose?
May 04, 2013 | Hayward SAND FILTER, PRO SERIES
If the spider gasket in the vari-flo valve is no good, you will usually notice one of two problems.
1. Water leaking out backwash port while filter is operating.
2. Valve positions are really difficult to change.
The way to check this is if you are able to move one or two of the "spokes" in the gasket freely(out of the track it sits in) once the top of the valve is removed.
If so you need to replace. The gasket is usually held in with a silicone sealant. Once you remove the old gasket. You will need to scrape any remaining rubber from the track it sits in. I've found that a brass brush from a pluming supply store or home depot along with a flat head screwdriver is usually enough to do the removal.
I always used Permatex Blue RTV sealant on all valve jobs. It can be found at any auto parts store or sometimes Walmart. Follow the instructions for curing. Once cured the gasket is good as new.
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Glass part that screws on is broke
It is the sight glass. If you would like a quote, contact us at www.arrowpools.net for one.
Jul 11, 2009 | Hayward SAND FILTER, PRO SERIES
Problem with vari-flo multipoer 1.5 and Hayward DE fiilter
You need a rebuild kit for the valve and possible a sand change. Sand should be changed ever 3 - 5 years or so depending on overall pool conditions.
The gasket inside the valve is out of place and therefore allowing water to leak out the waste port. Use a gokit to replace all the gasket/orings and you should stop the leak.
If the flow is still bad, inspect the sand and change it if necessary.
Jun 26, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward vari flo filtering system
Check to make sure the plumbing is in the correct inlet/outlet on the valve head. Sounds like it's plumbed backwards. Inlet is from the pump, out to pool...
May 10, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward Pro Series Side Mount Sand Filter 30" S310s Logo
171 people viewed this question
Top Hayward Garden Experts
Craig Butler
Craig Butler
Bill Boyd
Pushkar Singh
Pushkar Singh
Are you a Hayward Garden Expert? Answer questions, earn points and help others
