Question about Amana AKS3040 Gas Cooktop
How can I fix / clean the burners / strikers on Amana AKS3040 gas cooktop? Only two of the four burners self-light, and I have to use matches for the others. I've already tried to clean them with a brush and then a q-tip but it didn't help. Is there something else I can do before calling a repair person to come to the house? Thank you,
    President:
  • 1,561 Answers
Most newer gas stove models have sealed stovetop burners. This
Before cleaning any gas stove or oven surface, be sure the unit is off and completely cooled. Steam burns can occur from wiping a hot surface with a wet cloth or sponge. Follow these guidelines for care and cleaning without damaging your gas stove or gas oven surfaces.
Most newer gas stove models have sealed stovetop burners. means they are completely sealed off from the burner box (area of the stovetop below the metal cook top). Sealed burners should never be removed by home owners - it's a job only for professionals during installation and service. Sealed burners also mean that food and spills cannot spill into the burner box, so removing the burners is not necessary in order to clean the stovetop. If you have an older model stove with a lift-up cook top, follow your manufacturer's instructions for opening the surface for cleaning.
Be careful to avoid the gas ports on your burners. If they should become plugged with debris, poke the ports clean with a toothpick or straight pin, or brush gently with a soft-bristled brush. For pilot-less stoves, check the port and area below the igniter wire and clear it as well. Debris left under the igniter can keep the gas burner from lighting.
Clean the solid cook top surface with soapy water. Avoid abrasives and harsh chemicals as they can damage the surface of stove top finishes like porcelain enamel. Rubbing alcohol and household ammonia diluted with water (1:1 ratio) are other good stove top cleansers that will leave your top shining.
Controls
Remove control knobs and wash them in warm, soapy water. For clocks and display areas, wipe with a damp cloth and dry. If you are cleaning the display with glass cleaner, spray it first on a cloth and not directly on the surface to avoid cleaner seeping inside the mechanisms. Replace controls after they are cleaned and turn each one on briefly to ensure proper replacement.
Take care.
Posted on May 28, 2010
No matter which knob I turn on, all 4 ignitors spark,
There is no fix. This is normal. All 4 ignitors will spark but the gas will only go to the burner where the gas is active.
Jun 11, 2014 | Amana AKS3040 Gas Cooktop
What should the burner placement look like
If it's a four burner cooktop chances are there are two the Same one bigger and one smaller. Usually they only fit one way
Mar 05, 2014 | Amana AKS3040 Gas Cooktop
Clicks but does not does not igite
Hello, thank you for your post. It sound like your saying the burners are not lighting up. Most of the time this is just a simple fix. Next time you turn on your burner notice were the igniter sparks this part of the burner needed to be cleaned. You should be able to take the burner cap off and the burner use a wire brush to clean the surface area so the spark has good contact. Take notice also of the igniter you will need to change it out if you see any cracks around the ceramic housing.
Happy Holidays! Please rate me "4 thumbs" if this information was useful.
Dec 21, 2010 | Amana AKS3040 Gas Cooktop
The igniter on the left front burner of the
YOU HAVE a shorted ign sw. some of these only came in a wire harnes of 4 . and if they don't change all four when in there .. mm hope this helped .. feed back pls ..
Jul 20, 2010 | Amana AKS3040 Gas Cooktop
Amana gas cooktop clicks when not in use
Take a look at the solutions that have been posted regarding igniters. i suspect a dirty or wet push-down knob. you will see that others have had water/moisture causing problems. drying mights solve it, but it may need a a bit of a clean. keep trying. it must have taken me a couple of hours to solve.
May 07, 2010 | Amana AKS3040 Gas Cooktop
No spark on left side burners
Hi, This could be caused by something spilled on the burner, look at the electrode where the spark comes from and clean it up and make sure the metal right above it is clean as well. You should see spark at each burner regardless of which one your turning on. Assuming everything is clean, if you don't see spark on 2 of the burners, it could be 2 broken wires or a defective spark module (not likely if right side lights). Good luck
Jan 16, 2010 | Amana AKS3040 Gas Cooktop
Igniter does not click when turned on.
first check the outlet if thers power or in breaker....if have power,ur igniter is broken thats why nid to replace...meanwhile use lighter for use to flame the burner....if u replace by it ur self...uncrew all screw in top or in burner base then remove stainless plate...u see the lillte box,remove it then buy in service center..but its expensive..tnx
Jan 14, 2010 | Amana AKS3040 Gas Cooktop
Burner won't light
is gas comeing out of the hole? sometimes by cleaning the orfice hole (food and debrie will get in there and plug the hole not letting the gas come through) i get a needle and poke it.
when you say it is sparking...When you turn the dial for that specific one you want ignited... That one is sparking? If so Great. This means you either have a plug or the valve is bad and not letting the gas flow through.
Apr 04, 2009 | Amana AKS3040 Gas Cooktop
Clearence to hood fan
I just had a similar cooktop installed with a micro over it. From the bottom of the upper cabinet to the top of the burner frames you need 33 1/2 inches and from the bottom of the micro to the burner frames you need a minimum of 16 1/2 inches.
Aug 01, 2008 | Amana AKS3040 Gas Cooktop
Amana AKS3040 Gas Cooktop Logo
255 people viewed this question
Top Amana Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Thomas Perkins
Thomas Perkins
Are you an Amana Cooktop Expert? Answer questions, earn points and help others
