Question about Dell Inspiron 1501 PC Notebook
Stop 0x0000007E (0xC0000005, 0x8A390AB3, 0xBA507B90, 0xBA50788C) i receive this when i start up my computer
    Problem Solver:
  • 12 Answers
Its the bsod (blue screen of death)
There is no way to sort this basically your computers doomed, you can get on your computer via safemode but not through normal windows sorry, i had the same problem with my old laptop
Posted on May 30, 2010
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Windows cannot connect to printer. Operation failed with error 0x0000007e.
This problem happens when you are trying to share printer between 32 bit (x86) and 64 bit (x64) Windows. The 32 bit driver not compatible for 64 bit operating system. At this situation you may get error message like this "Windows cannot connect to the printer Operation failed with error 0x0000007e".
But there is an alternate way to add printer from 32 bit Windows to 64 bit Windows.
Start >> Devices and Printers >>
Then Add Printer with the help of IP address of 32 bit Windows computer.
Detailed steps with screen shots are given in the following link.
[Solved] Operation failed with error 0x0000007e
Solved Operation failed with error 0x0000007e Share printer between 32...
Apr 11, 2012 | Xerox Office Equipment & Supplies
I am trying to boot up my pc and I just received STOP: 0X0000007E (0XC0000005, 0X82E89963, 0XF8AEF8B4, 0XF8AEF5B0
Hello.
The most common reasons for these errors are memory and hard drive problems.
To determine further, run the diagnostics for your computer. It varies from computer to computer, but try pressing F12 when booting.. It may be different for your computer.
If no diagnostics results available, try your memory, first. Remove all memory and place one at a time and boot your computer to test. If no difference, your hard drive is probably failing.
If the hard drive is bad and you want to try to retrieve your files, set your hard drive as a slave and install in another computer. You may need on-site assistance with this.
Hope this helps.
Oct 01, 2010 | Computers & Internet
When my Gateway 300S is powering up, it recycles.
If you repeatedly hit F8 key when the computer starts to boot it will open the boot menu screen. There should be an option to "halt computer on all errors". This should bring up the blue screen of death. It should give you something like
STOP: 0X0000007E, the a whole bunch of other numbers. after that it may display a file name. You can search the internet for STOP: 0X0000007E and the file named mentioned. You may be able to find a solution by doing this. It is usually caused by a bad driver or executing a bad command on Windows start up. You can boot the computer in safe mode from the boot menu and maybe repair the problem but it's a tough one to find. I'm trying to repair a similar Gateway computer. It doesn't list a file name and I'm pretty sure that it's a video driver or the onboard video card. The problem is Gateway is no longer in business and it's hard to find updated drivers I"m going to try to backup all the files on the drive and re-install windows and try to repair the drivers with more updated ones. The gateways are hard because they don't have slots in the motherboard to install anything but an old PCI video card. It may be time to think about a new computer soon.
Nov 14, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
Windows BSOD on all restarts, even in Safe Mode and even if I start with video in VGA mode. Stop code is 0x0000007E plus four more codes in parentheses. During Safe Mode restart the last file to appear on...
7E is a memory issue or general driver fault. It's windows way of saying "i dunno it just died". If you have Dell diagnostics, run a full system check, to ensure the hardware is ok. If you get no errors, then you have a driver fault in windows. This is From Microsoft:
If the following conditions are true, the issue might be a hardware incompatibility with Windows XP because all the installed drivers are Windows XP drivers:
  • You receive the STOP 0x7E error when you first start the computer.
  • You receive the STOP 0x7E error after you run the Setup program.
  • You did not install any third-party drivers during the installation of Windows.
However, if you receive the STOP 0x7E error after you upgrade from Windows 2000 Professional, or if you recently added a new hardware device, this issue might be an incompatible driver or an incompatible hardware device.
Basically, the 7E error is a defective driver. You will likely have to get your computer recovered by a professional shop, or if you have nothing important on it, attempt to reformat and reinstall. It is unfair that Windows has borked your computer and they wont fix it. I hope I was able to at least point you in the right direction.
Oct 26, 2009 | Dell Inspiron 700M Notebook
Error code 53000:031e stop:0x0000007E COMPUTER WIIL NOT BOOT UP
hi there !
-boot to SAFE MODE
-restart the computer and press F8 and choose SAFE MODE then do the steps below
Windows Update Causing STOP Error 0x0000007E
-For now simple system restore should fix the issue, else uninstall this update by booting to safe mode.
-Uninstalling windows update KB973879 and hiding this update from available update is currently seem to be fixing the issue.
In case if removing update KB973879 doesn’t fix the issue, we need to remove remaining two updates KB970653 and KB972036.
cheers!
Oct 20, 2009 | Dell Latitude D510 Notebook
I have a Dell Inspiron 530 0X0000007E error code
That error message is usually coupled with removing an adapter connected to a RAID device. Have you disconnected anything in your computer recently? Have you opened it and cleaned it recently? If you've opened it to clean it, there's a chance that something may have come loose. If you know what you're doing on the inside of a computer, you can go through and make sure that everything is properly connected and then try booting again too see if that works.
Oct 17, 2009 | Dell Inspiron 530 Desktop Computer
Stop: 0x0000007e
Upgrade to vista or windows 7, Xp is not supported by microsoft anymore (BUMMER)
Sep 30, 2009 | Microsoft Windows XP Home Edition
Balance - Blue Screen during shut down stop error 0X0000007E
check your hardware settings it could be the codes for the hardware that cannot recognize of your systems. it could be change with the wrong specs. if you cannor configure it out. you better set the bios configuration to default setting and try to repair the system using your operating system cd installer. thanks
May 11, 2009 | Computers & Internet
0x0000007e error code in acer motherboard of win
hi,
Some users experienced similar problems when SP2 was released, so this could be the problem. If the user sees a stop error code of 0x0000007e, this first issue is likely the reason why the computer does not boot properly.
The second issue will only occur on systems with certain acer motherboards. This error manifests itself with an error code of STOP: 0x000000A5. It is unknown how to fix this problem other than by installing a USB storage device, or even possibly removing a USB mouse and replacing it with a PS/2 port compatible version.
If that is not enough, Microsoft MVP Jesper Johansson reports that there seems to be a third, less common problem with SP3 computers, this time on Intel. Some may receive a 0x00000024 stop error, which he believes may be due to an issue with either the NTFS file system being corrupted, or a faulty video driver.
go to microsoft .com under solutions page and type in the information code error they have been working on a dowload patch to correct this . go there http://support.microsoft.com.
Mar 30, 2009 | Acer Computers & Internet
Dell Inspiron 1501  PC Notebook Logo
221 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
