Question about Toshiba SD-P1900 Portable DVD Player
Used three times, three week old Toshiba dvd player showing a No Valid disk prompt and the disk is not spinning.
  • Toshiba Master
  • 6,993 Answers
that's electronic for you! Anything can happen at time.
Since its not been long you've been using the player, then the problem shouldn't be from the laser (lens) because the laser (laser) is the first one should check if a player cannot read disc.
The problems should be a mechanism fault. When disc is inserted into the player, the laser should raise up and read the data on the disc. But since its not doing so, then it needs some adjustment.
Mechanism fault are usually though to fix, so I would advice that you take the player to a tech to help fix the fault.
Good luck.
Posted on May 28, 2010
How do i fix my toshiba dvd player?
Select correct input in your tv. Look for cable conections and the correct input in your tv.
Aug 03, 2014 | Toshiba Televison & Video
Not a valid disk
HI,
The problem is with the DVD player.Pleas use a leans cleaner to clean the lens.
I will give you more home remedies if they don't help then you will have to get this repaired.
Oct 12, 2008 | Toshiba Televison & Video
DVD
Try using a DVD lens cleaner
Sep 10, 2008 | Toshiba MW27H62 27" TV/DVD
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
My Trutech television (model PVS31170S1W 17 in. LCD) is malfunctioning. The dvd player, which was just working last week, all of a sudden is not spinning the disks and any dvd we put it comes up as "no...
Often overlooked is tha fact that if you switched to another input, the dvd motor will not spin? Check that first, not switched to another input to the TV or the LCD screen? Otherwise, it is easy to replace the dvd unit.
Aug 15, 2010 | TruTech PVS31170S1W 17 in. LCD Television
My Toshiba portable dvd player says no Valid Disc
If the units under warranty you may want to contact Toshiba as it sounds your unit is in need of a replacement laser assembly.
If the unit isnt under warranty, Toshiba should be able to supply the parts you need and as long as you mark every thing that you remove, as to know where it goes when re-assembling the unit. The lasers arent difficult to replace. Good luck.
Jun 07, 2010 | Televison & Video
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
No Valid Disc - Toshiba SD-P1900
Same thing with mine. was hoping you had a solution. :( guess I have a nice paperweight.
Mar 12, 2009 | Computers & Internet
Yep sone of a gun ! With the Toshiba Portable DVD Player, hold the "Mode button" down for several seconds and it will make a chain saw noise take your finger off, hit it again once and bingo now it works. I was ready to throw this player in the trash!
Jan 17, 2008 | Toshiba SD-P1900 Portable DVD Player
Toshiba SD-P1900 Portable DVD Player Logo
130 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
