Question about Frigidaire FRS26H5AS Side by Side Refrigerator
Refrigerator side is freezing.
The refrigerator side keeps freezing even when the thermostat is turned down to 1. what is the defective part? Please reply.
  • 619 Answers
The damper control which is the control for the refrigerator has gone bad not letting the damper door close to control the airflow into the fresh food section. the part number is 5303918283 at a price of about 245.00. To me this is rediculous but that is the manf suggested retail. It should be a crime to charge so much for this particular part. Soory on the cost but it is the problem.
Posted on Jun 02, 2010
Refrigerator side keeps changing to lower temp
I think your thermostat is defect. Not registering the correct temperature. dial in a higher temp for the time being, but (let) replace the thermostat.
Jul 17, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Coil freezes
perhaps the drain is plugged in the freezer.
Have you checked this, please let me know what you find and we can go from there to figure this out.
May 12, 2008 | Hotpoint HSS25GFP Side by Side...
Where is the thermostat located on a frigidaire gallery model GLRS2642AQ6 Electrolux side by side. Keeps freezing up even after turning down both side to just cold.
Hi this is most likely the damper assembly not the thermostat, the damper assemly is on the left side of the refrigerator compartment in the very top corner up there, sometimes depending on the model this damper runs 3/4 of the length of the left wall there. This entire assembly needs changed.
Sean
Mar 28, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
My fridge side out the blue is freezing. All
I had the same problem with mine a few years ago. After two thermostat replacements and still having the problem, the third technician out explained that if you blocked the vent on the inside of the refrigerator, (the shelf below meat drawer,left side) it could cause freeze up. Sure enough, haven't had a problem since.
Mar 29, 2010 | Frigidaire FRS26R4A Side by Side...
I have a 3 yr old side-by-side. The freezer is freezing ice cream solid even though it's turned all the way down. Food in the bottom two drawers on the refigerator side are freezing. Water has dripped...
Hi, this problem is going to be with the running thermostat. (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Power failure in the area, everything is freezing in fridge
If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Jul 13, 2009 | Refrigerators
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
May 08, 2009 | Refrigerators
GE GSS25PGMCC refrigerator freezing food
hello I think that this is what you are looking for . Hope it helps you out with your problem.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60218.pdf
Thank You for using FixYa
Dec 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag Wide by Side (5 years old) Freezing Refrigerator & Freezer
There is 2 things you can replaced to rectify this problem .
1 is the defrost timer and the next is the thermostat.
On the thermostat is a metal rod that is connected to a vent so when you adjust it it open or closes the vent .Just make sure that is not loose because if it's loose even though you turn thermostat down the vent would be wide open allowing freezing air to get into refrigerator.
Jun 03, 2017 | Maytag MZD2752G Side by Side Refrigerator
Frigidaire FRS26H5AS Side by Side Refrigerator Logo
307 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
